First beta-quality Android N release is now available
Update: The first beta update appears to be rolling out right now. Be sure to enroll your device at the link below, and check for the update.
Google has announced that it will be releasing the first beta-quality Android N release later today. This release is supposed to be good enough to install on the phone and tablet that you use daily. This is a huge step, as the previous releases were called Developer Previews, and had various issues that may have prevented you from using it daily.
You can enroll your device at Android.com/beta if you want to be ready for when it releases. Will you be enrolling your Nexus for the program, or will you be sticking to an official release for now? Sound off in the comments and let us know which side you are on.
More: Google I/O 2016 coverage
Jared started off writing about mobile phones back when BlackBerry ruled the market, and Windows Mobile was kinda cool. Now, with a family, mortgage and other responsibilities he has no choice but to look for the best deals, and he's here to share them with you.
