Fill your home with smart plugs at less than $5 each with this Amazon deal
Smart home technology is becoming more affordable than ever as we reach the end of 2019. Add smart compatibility to older electronics and appliances inexpensively with this 4-pack of Aoycocr 15A Smart Plugs. Prime members can pick it up for just $18.89 today when using promo code 408JBLKV during checkout at Amazon. If you're not a Prime member, you can still use the code to save on these smart plugs and drop their total cost down to $20.39. As they normally sell for around $32 on average, even snagging the 4-pack at $20 is a great deal.
These 15A smart plugs are capable of monitoring the energy usage of whichever appliance or electronic is currently plugged in, allowing you to end high power consumption and save money in the long run. These smart plugs are even compact enough so that two can be used stacked beside each other, or you could just use one and have space to plug in another power cord above or below it.
Smart Lights Led Bulb Daylight Aoycocr(6500K) 7.5W A19 - Medium Screw Base (E26) - 750 Lumens(65W equiv.) - Dimmable - RGB Color Changing - Voice Control - No Hub Required - UL Listed - 4 Pack
$20.99 $40.99 Save $20
Aoycocr Smart Light Switch
Starting at $10
These smart light switches can be controlled using an app on your phone or even with your voice! Amazon's offering an additional 50% off which shows at checkout; you can grab one for $10 or two for just $17!
Aoycocr Mini Smart Plug (4-pack)
$19.79 $31.06 Save $11
These smart plugs can be controlled using an app on your phone or tablet, or even with your voice! No hub is required, and today's sale saves you 40% at checkout instantly. That brings them down to just $5 each.
$19.79 $32.99 Save $13
Appliances you already own can be controlled with your phone with help from these mini smart plugs. Adding to your cart via this link scores you 1 for $7.79 or 4 for under $5 apiece.
Aoycocr BR30 dimmable LED multi-color smart bulbs 4-pack
$33.59 $53.00 Save $19
Aoycocr's BR30 smart bulbs are perfect for recessed lighting fixtures and anywhere you need some directional smart lights. Don't require a hub and work with Amazon Alexa and Google Assistant. Set schedules and routines with the free smartphone app.
Using an app on your phone, you'll be able to set schedules for these smart plugs to power on and off. You can control them manually within the app from anywhere in the world, or set Away Mode on which turns your smart plugs on and off at random to make it appear as if someone's still at home. Unlike many others, no hub is required to use these smart plugs, though you'll want to make sure you have a device featuring Amazon Alexa or Google Assistant as they'll allow you to begin voice controlling these plugs. The plugs support IFTTT as well.
A one-year warranty is included with this purchase. At Amazon, close to 100 customers have left reviews for this 4-pack resulting in a rating of 4.7 out of 5 stars.
