Equip your home with a discounted Ring doorbell or alarm and get a free Echo device
From video doorbells to outdoor cameras and even alarm systems, Ring makes some really great home security hardware. While most of it is decently priced already, you shouldn't miss any opportunity to save some cash on your purchase, especially when it's not only discounted but also bundled with some freebies. Some of Ring's hardware is currently bundled with a free Echo Show 5, some with an Echo Dot, and some of it is just marked down in price.
These discounts bring the price of many of these back down to previous low prices, and when you factor in the cost of the freebies it makes them even more affordable than ever before. To take advantage of some of these discounts, you'll need to be an Amazon Prime member. If you aren't already, you can sign up for a free 30-day trial now to lock in the discounted prices below.
Ring Video Doorbell Pro w/ Echo Show 5
The Video Doorbell Pro is one of Ring's best options, but it does require you to have the ability to hardwire it at your home. This means that you'll need to be replacing an existing wired doorbell, or have the option to run wiring to the location. With this, though, you gain features like Pre-roll, which shows you a few seconds of the clip before motion is detected, and it also means that you don't have to worry about charging the battery.
It comes with a few different face plate options so you can find one to match your home, and the box also includes two adapters for mounting it in different situations. You can use the free Echo Show 5 to answer your doorbell and communicate with your guests, instead of having to pull out your phone. This bundle is $50 less than buying just the doorbell by itself, so don't miss out.
Ring Video Doorbell 2 in used condition
$69.99 $100.00 Save $30
This is fully functional unit tested by Amazon that may have cosmetic imperfections. It is sold by Woot and the price is available for only one day. Record video in 1080p resolution. Use your phone, tablet, or Echo device to see, hear, and speak.
$159.99 $249.00 Save $89
The Ring Video Doorbell Pro lets you see and speak with whoever's at your home's front door using an app on your smartphone. It's easy to install too and connects to your existing doorbell's wiring for power.
Ring Video Doorbell (2020 Release)
$79.99 $99.99 Save $20
Best Buy's one-day sale on the latest Ring Video Doorbell can save you $20 instantly. You can even bundle it with a Ring Chime for $20 more and score a free Echo Dot smart speaker with the purchase.
Ring Video Doorbell Pro with Ring Chime Pro
$99.99 $204.98 Save $105
Buying refurbished at Amazon is always a smart idea. The items are like new and have been tested to ensure they're in proper working condition. You'll even receive a full warranty and a free Ring Chime Pro with today's offer.
Ring Alarm 2nd-generation 5-piece kit with free Echo Dot
$119.99 $200.00 Save $80
Get it faster if you don't care about the free Echo Dot. This 5-piece kit comes with a base station, keypad, one contact sensor, one motion detector, and one range extender. Add other sensors and keypads and such as you need. Works with Alexa.
Ring Video Doorbell 2 w/ Echo Show 5
If you can't install the Pro option at your home, or just want to spend a little less, the Video Doorbell 2 is a great option. This one can be powered solely by the rechargeable battery inside, but if you happen to have wiring already run you can hook that up to the back of it so that you don't need to charge the battery at all. It has a larger overall footprint, but offers the same 1080p video feed that the Pro does.
Ring includes a few different faceplates for it, and you can buy an extra battery if you prefer to have one to just swap in to limit downtime. The Show 5 can be used to view, answer, and interact with the Video Doorbell 2 as well.
Ring 5-piece Alarm w/ Echo Dot
Home security systems have become so much more affordable these days, and some of them (like this one) you can even install on your own. From unboxing to fully installed, the Ring Alarm System can be ready to use in less than an hour and doesn't require much knowledge to get going. Ring offers 24/7 professional security monitoring for $10 a month or $100 a year and there are no contracts involved. That's way less than most other companies are offering, and the cost of the actual hardware is cheaper as well.
This kit comes with the keypad, base station, network extender, motion sensor, and a single door / window sensor. You can easily add and expand the system as needed with limited effort. The free Echo Dot can be used to arm or disarm your alarm using just your voice, which is quite awesome.
Ring Floodlight Cam
There are a few different outdoor security camera options from Ring, but this one is a great replacement for anyone who already has floodlights installed at home. It features two bright LED lights and a camera in the middle. The camera shows a 1080p video feed and you can use the free Ring app on your phone, tablet, and PC to interact with visitors or trespassers. It has a built-in siren if you want to scare something off, and Ring backs it with a lifetime theft protection, in case someone tries to steal it.
This discount brings the cost of the new version down to the same as the refurbished one, so you won't want to miss out on it.
Odds are that these deals won't stick around for too long, so be sure to grab one (or two) of these now, so you don't miss out.
Jared started off writing about mobile phones back when BlackBerry ruled the market, and Windows Mobile was kinda cool. Now, with a family, mortgage and other responsibilities he has no choice but to look for the best deals, and he's here to share them with you.
