Enhance your audio with the Soundcore Liberty Air true wireless earbuds down to $55 today
Update: The one-day sale on the black headphones has ended, but you can still grab the White pair for $55.99 for a limited time!
The Anker Soundcore Liberty Air true wireless earbuds are down to $55.30 on Amazon today. These earbuds normally sell for around $80. We have seen them go on sale a couple of times, but today's drop marks a whole new low. The white earbuds are going for almost the same price, too.
This is one of Amazon's daily deals, and it's part of a larger sale featuring a ton of Anker accessories up to 48% off. Get a wireless charging pad, a portable power bank, or any one of a dozen other items all down to super low prices. It all disappears tonight, so go for it while you can.
Anker Soundcore Life Q30 hybrid active noise-cancelling Bluetooth headphones
$59.99 $79.99 Save $20
These hybrid Bluetooth headphones reduce ambient noise up to 95% thanks to active noise-cancelling mics. The battery lasts up to 40 hours with ANC on or 60 hours with it off, and recharge via USB-C. Clip the $20 on-page coupon.
Anker Powerline II 6-feet USB-C to Lightning cable
$12.74 $15.00 Save $2
When using a USB-C power adapter (not included), you'll get the fastest possible charge for your iPhone. Plus you can seamlessly sync and charge your Mac. This is Apple MFi certified and lasts 12 times longer than other cables.
Anker Liberty Air 2 Pro true wireless earbuds Best Buy
$79.99 $130.00 Save $50
These earbuds have active noise-cancelling that's customizable with a simple app. You'll get a total of 26 hours of playtime with seven hours from a single charge and the rest from the charging case. Uses USB-C and has wireless charging.
Anker Soundcore Rave Neo portable Bluetooth speaker with LED lights
$84.99 $120.00 Save $35
Includes a rechargeable battery that will last for up to 18 hours and can charge other devices with the USB port. IPX7 rated for water resistance. The built-in LED lights will sync to the music you're playing. Connect multiple speakers together.
Anker Soundcore Liberty 2 Pro true wireless earbuds black
$49.99 $100.00 Save $50
They last for up to eight hours on a single charge with up to 32 hours total using the charging case. They have quick charge so you can get two hours after 10 minutes spent charging. They also charge via USB-C or a Qi wireless charger.
The Liberty Air have audio technology enhanced by graphene so what you end up with is accurate and clear. Pair these earbuds with your favorite mobile device and you'll be jamming to all your favorite tunes.
Each earbud has a battery that lasts for up to five hours. You can use a single earbud or use both for stereo sound. Personally, I like to use my earbuds one ear at a time so I can charge the one not in use and hot swap as needed. The charging case they come with adds another 20 hours before you need to worry about finding a wall outlet to plug into.
The earbuds also have a mic built into each so you can use them answer phone calls. The mics have noise-cancelling technology to help eliminate ambient sounds. They also enhance voice pick up. What you get is crystal clear phone calls every time.
Just tap the earbuds for simple touch control. You can play, pause, skip tracks, and answer calls without even looking at your device.
This set comes with Anker's 18-month warranty. You'll also get custom ear tips so you can find the perfect fit.
