Droid Incredible 4G LTE update on the way
Minor update reduces power cycling and adds ISIS support
HTC Droid Incredible 4G LTE owners will be happy to know that Verizon Wireless appears to have approved an update for the device, according to some new documents on their website. While the update isn't a new version of Android, like KitKat, it does help improve the performance of the device, and that is always welcomed.
Verizon has posted the changes that are found in the new software, version 2.19.605.2 710RD, and the changes are -
  • ISIS Mobile Wallet is now supported
  • Software Upgrade and Software Repair Tools are now compatible
  • Power cycling has been reduced
  • Bluetooth® clarity has been improved
  • Security patches have been added
If any of these issues impacted your device you will definitely want to be on the lookout for this update, and even if you aren't having many issues you will want to update. Seeing the update on your device yet? Be sure to let us know in the forums any issues you come across during the update.
Source: Verizon
Jared started off writing about mobile phones back when BlackBerry ruled the market, and Windows Mobile was kinda cool. Now, with a family, mortgage and other responsibilities he has no choice but to look for the best deals, and he's here to share them with you.
