Drive safer with over 30% off iOttie's magnetic phone mount at Amazon
You are now subscribed
Your newsletter sign-up was successful
Driving is dangerous enough without having your phone in your hands at the same time. If you don't have a mount for your phone in your vehicle already, it's way past time to snag one. Luckily, several of iOttie's best mounts are on sale at Amazon today with prices starting at just $16.95. Each mount is built to fit for a different location, so it'd be wise to check out your vehicle before buying and see where a mount would work best.
The mount which most vehicles should be able to use is iOttie's iTap Magnetic Dashboard Mount. Now on sale for $16.95, today's sale saves you more than 30% off its regular price of $25, and this deal matches the lowest it's ever reached too.
On the other hand, iOttie has a model which clips into your air vent and another which slides into your CD player slot. They're on sale for $16.95 and $17.95 respectively, and either option is not just a worthwhile pickup but a great deal as well.
The iOttie iTap Magnetic Dashboard Mount is capable of holding most smartphones, with or without a case. It comes with metal places that you stick to your phone with adhesive tape, or place between your phone and its case, so you can magnetically attach your phone to the mount with ease whenever you get into your vehicle.
The base is built compact enough to never be in your way while you're driving, and it's even able to rotate your device 360 degrees so you can view it in either portrait or landscape mode. At Amazon, nearly 1,150 customers left a review for this mount resulting in a rating of 3.9 out of 5 stars.
