Vantrue is offering a number of discounts on its dash cams via Amazon with as much as $70 off. The varying models on sale start at just $51.99 and help you stay prepared for whatever the road throws at you. All you have to do is enter the correct coupon code during checkout.
Vantrue T2 1080p dash cam with motion detection
$89.99 $150.00 Save $60
Clip the on-page coupon and use the code for a stacked discount. Has a wave detection sensor that can detect motion and start recording. Stays charged and avoids battery draining. Includes enhanced night vision and loop recording.
Vantrue T2 24/7 recording 1080p dash cam
$99.99 $150.00 Save $50
Has a wave detection sensor that can detect motion and start recording. Stays charged and avoids battery draining. Includes enhanced night vision and loop recording. Resists extreme temperatures up to 158-degrees Fahrenheit. 18-month warranty.
Vantrue N2 Pro Uber high-definition dual dash cam
$119.99 $200.00 Save $80
The front records in 1440p with a 170-degree angle lens, and the back records in 1080p with 140-degree field of view. Includes night vision, parking mode, and more. Has built-in mic and speaker for full audio. Resists heat and protects itself.
Vantrue N2 Pro 1080p dual dash cam
$142.99 $200.00 Save $57
$150.00 $199.99 Save $50
The most affordable camera in the sale is the Vantrue N1 Pro Mini at $51.99 — a new record low price. This compact dash cam was designed to make sure it doesn't obstruct your vision while you're on the road. It records 1080p HD video at 30fps and features a 160-degree wide-angle F1.8 six-layer glass lens that offers enough clarity to capture license plates and more. There's a motion-activated parking mode which begins recording automatically if motion is detected directly in front of your car while it's parked, as well as seamless loop recording and a G-sensor that will ensure footage from a collision is locked down and not overwritten. An integrated microphone helps to record audio during each recording as well.
If you need something more professional-grade, you could step it up to the Vantrue N2 Pro Dual Dash Cam for $129.99. It regularly sells for $200 and is designed especially for people that drive for rideshare services like Uber and Lyft. The powerful cameras simultaneously capture road footage and the inside of the cabin. You can also switch it to only the 1440p front camera. This device automatically starts up once you turn on your vehicle, and the LCD light turns off after a few moments to prevent distractions. The interior camera uses four IR lights, meaning recording will still work, even in the dark. This also features parking mode, where the cameras will automatically start recording if they detect motion when your car is parked. There's audio recording as well.
Vantrue is also offering its S1 Dual Dash Cam for $169.99, a $30 discount, with code SPLNQ3OV.
Be an expert in 5 minutes
