Does Tello Mobile allow Hotspot use?
Best answer: Yes, Tello Mobile does allow hotspot use. It's included for free with any plan you choose, meaning you don't have to pay a penny more just to tether with your other devices.
- Free hotspot: Tello (From $5/month at Tello)
- Perfect for Tello: Google Pixel 3a ($393 at Amazon)
Tello doesn't charge extra for hotspot use
Tello is a wireless carrier with a ton of great features, including free hotspot access!
Some of Tello's competitors charge $10/month to use your phone's hotspot, meaning you could potentially save $120 every year just by signing up for Tello and using your hotspot for free.
Using your phone's hotspot is also dead simple. Just hop into its settings, find the section for "network & internet," and you should see a section for hotspot and tethering. Here, you can turn the hotspot on, adjust its security, password, and more.
The hotspot feature counts against your regular monthly data
When you use your phone's hotspot on Tello, any data that's used simply counts against your regular monthly data allowance.
Be an expert in 5 minutes
Have a Tello plan with 4GB of monthly data? You'll share that 4GB between data you use on your phone and whenever its hotspot is enabled. If you're a particularly heavy user, it's probably worth splurging for the 12GB data option.
It's also worth remembering that your monthly data allotment is for LTE data. Once you've used up your data for the month, you can keep on using unlimited 2G data. It'll be quite a bit slower, but good enough for basic web browsing, calling an Uber, using Google Maps and light versions of social media apps
Joe Maring was a Senior Editor for Android Central between 2017 and 2021. You can reach him on Twitter at @JoeMaring1.
