Does the SmartThings WiFi mesh router include a smart hub?
Best answer: Yes — the SmartThings WiFi mesh router system also doubles as a smart hub that can connect up to 100+ different SmartThings gadgets.
Amazon: Samsung SmartThings WiFi Mesh Router ($280)
The SmartThings WiFi mesh router doubles as a smart hub
The SmartThings WiFi mesh router is really two different products in one.
In addition to providing ample Wi-Fi coverage for your home, it also works as a smart hub for all of your other SmartThings devices. So, if you were already planning on getting a mesh router system and are invested in the SmartThings ecosystem, going this route just makes sense.
Everything's controlled through the SmartThings app
Whether you want to turn off your lights, adjust the thermostat, or customize your home network settings, everything is controlled through the main SmartThings app.
Be an expert in 5 minutes
For buyers that already use the app for controlling other smart home devices, having your Wi-Fi options handled through here too is a really nice treat.
You can buy a single router or get a three-pack
If you're interested in buying the SmartThings WiFi system for yourself, you can purchase just a standalone unit or pick up a three-pack for maximum coverage.
Although it's more expensive upfront, we recommend going the three-pack route as it offers excellent Wi-Fi range (up to 4,500 square feet) and provides the most bang for your buck at around $93 per router instead of $120.
Joe Maring was a Senior Editor for Android Central between 2017 and 2021. You can reach him on Twitter at @JoeMaring1.
