Does Mint Mobile allow you to upgrade to the Unlimited plan?
Keep things simple with Mint.
Best answer: Yes! You can upgrade to an unlimited plan or any mid-cycle plan by paying the difference between your current plan and the upgraded one. To do this, log into your account and follow the on-screen instructions. You can also choose to have your upgrade take effect at the end of your current plan.
Mint Mobile: Starting at $15/month
Now owned by T-Mobile, Mint Mobile is an affordable prepaid carrier that sells wireless in 3, 6, and 12-month increments of time. Four plans are available, including an Unlimited plan with a data cap of 40GB (after which speeds slow). If you choose to upgrade to a higher tier before your plan wraps up, you can do so at any time — you'll just need to pay the difference between your current plan and the new one.
- MVNO deals: Mint Mobile | Visible | Boost | Tello | Cricket
How to change your Mint Mobile plan
Is your current Mint Mobile plan just not enough anymore? Mint Mobile makes it easy to upgrade to a higher-tier plan whenever you want, as long as you're okay with paying the difference in cost. Switching to a plan that best fits your needs will get you the needed data.
Log into your Mint Mobile website or app account, scroll to My Plan, or select Manage Plan at Mint Mobile's portal. Follow the prompts to make the change immediately effective. Mint Mobile will direct you to a Checkout page where you can pay for the difference between your current and upgraded plans.
Downgrading isn't as straightforward as upgrading. You can only do so when your billing cycle ends, not mid-cycle. Whether you're upgrading or downgrading, you have the flexibility to select between three-, six-, or 12-month plans.
Starting with a shorter term might be wise if you aren't sure how much data you'll use in a month. It's important to know that you can't change the duration of your plan once it starts. If you must choose another one, you must wait until your current plan ends. You can also set up a new plan duration to automatically renew when your current plan ends by logging into your account.
It's also worth noting that Mint's Unlimited plan slows after 40GB but doesn't end. If you think you'll use more than 40GB in a month, you might want to consider one of the other best MVNO carriers out there. What do you get with the Mint Mobile unlimited plan? You get unlimited talk and text (5G), Free calling to Canada and Mexico, a 10GB mobile hotspot, Wi-Fi calling, and instant plan activation. Mint Mobile doesn't include contracts, and you can even bring your phone.
Mint Mobile offers four monthly data plans: 5GB, 15GB, 20GB, and Unlimited (40GB). All these options are affordable and come with instant access to T-Mobile's vast 5G network; the catch is that you must pay for your wireless service in bulk.
If you need more data than you anticipated before your cycle wraps up, you can upgrade to a higher tier at any time by paying the difference in cost between the two plans.
Be an expert in 5 minutes
