Best security cameras that work with Amazon Alexa 2024
Amazon Alexa is a great way to integrate your security cameras with your smart home — and these are the best.
A Wi-Fi-enabled security camera is an excellent way to keep an eye on your home while you're away. If you can find an Alexa-compatible security camera, it makes watching over your home that much easier.
For example, you can check in on the pets while you're at work, and, in the case of those with built-in microphones, quickly tell your kid that they're supposed to be studying instead of playing video games. With these cameras, you can ask Alexa to show you what is happening at any point in time and connect your cameras to Alexa routines and smart light bulbs for further home automation. These are some of the best security cameras that work with Alexa.
Check out these awesome security camera deals
Staff pick
Top brand
Arlo Pro cameras are some of the best money can buy, period, and they also integrate well with Alexa. The new Arlo Pro 5S 2K carries on the legacy of the Pro 4, and expands upon it with support for 12x zoom. It features up to 2K video recording with HDR, dual-band Wi-Fi, color night vision mode, and extended battery life with low-power mode.
Smart home
The 2nd Gen Google Nest Cam (indoor, wired) is totally redesigned, and comes in three new shades to blend in with your home decor. It gives you a 24/7 live stream of your home, and alerts in the Nest Aware app. The adjustable stand lets you place it on a wall or table, and it's super-easy to set up. Despite it being a Google product, you can control it via Alexa with the Smart Home skill.
Blink out
Blink's 4th generation outdoor camera comes with some nifty upgrades like a massive 143-degree field of view, improved motion detection, dual-zone motion alerts, and person detection (for subscribers). The rest of the features are similar to the Outdoor 3 like a two-year battery life, weatherproofing, and two-way comms. You can store files locally with the Blink Sync Module, or you can take advantage of the cloud storage plans.
Integrated security
For 24/7 professional monitoring, the Ring Spotlight Cam Plus Wired is your best option since Ring offers Protect plans. These cameras also have full HD live streaming and recording, two-way audio, night vision, and lifetime purchase protection from Ring. Plus, stolen cameras are covered.
Blink in
The Blink Indoor (3rd Gen) camera shares all of the company's Outdoor cam's specs and features, minus the weatherproofing. This accounts for the price difference, so if you don't need weather resistance, this is a solid and more affordable Blink alternative for your indoor or sheltered spaces.
Indoor or outdoor
I've really enjoyed using this wired security camera because it can be great inside or out with its wide-angle 2K HD live-streaming footage, and you can record 24/7 and save it all to a microSD card. If you want cloud storage, Kasa offers that too! You'll even get a flood light to make sure you get a perfect image, day or night.
Little one
While this is a wired-only camera, it offers many of the same features as the pricier Blink Indoor camera at a fraction of the price. The Mini 2 is about $10 more than the original, but you get major improvements like built-in spotlight, wider field of view, person detection, and it can be used outdoors. Plus, you can use the Blink Add-On Sync Module 2 to store your video files locally.
Budget pick
The latest Wyze Cam v4 can record 2.5K resolution video, along with color night vision footage. It can be used indoors or outdoors, has an IP65 rating, a motion activated spotlight, and person detection. It supports 24/7 recording straight to a microSD card, two-way comms, and an upgraded image processor for wide dynamic range capture.
Pan and tilt
The latest Wyze Cam Pan v3 has a quirky new design, an improved 180 degrees of vertical motion, and is IP65 rated. The weather resistance makes it ideal for even outdoor use. It can automatically track and follow a target when it detects motion. Activating the privacy mode pans the camera downward and powers off. It has two-way audio, color night vision, and is surprisingly cheaper than the older model.
The best security solutions for your smart home
The best Alexa devices combine excellent features with ease of use and convenience. For a great Alexa-compatible security camera, you really can't go wrong with the Arlo Pro 5S 2K. Though it is on the expensive side, with its excellent feature set, and solid Alexa integration, it is a winner.
If you're looking to complement your Ring Video Doorbell, then you'd do well to pick up the Ring Spotlight Cam Plus Wired. The Ring Protect plans are inexpensive, and they come with other awesome features, like Ring Neighborhoods, which send you real-time crime and safety alerts from other Ring users in your area. Plus, you'll have all of your smart security taken care of in one app.
Blink makes some excellent cameras, and its upgraded Outdoor 4 is a great choice if you need a wide field of view and dual-zone motion alerts. For the best flexibility, it's hard to beat the range of motion of the Wyze Cam Pan v3. For its relatively affordable price, you get 360 degree horizontal motion and 180 degree vertical, thus eliminating most blind spots with just a single camera.
Be an expert in 5 minutes
Olivia Lipski is a freelance writer for Android Central and loves testing out the latest smart home tech and discovering the best cell phone plans. When she's not busy running around NYC trying to find great food or coffee, she's in her kitchen trying to make it herself.
- Roydon CerejoContributor
