Do more for less with the $9 Aukey 4-port USB Hub
It seems silly that we're almost in 2020 and it's more of a struggle to connect multiple devices to your computer now than it has been in years. Everything needs to be plugged in and your computer probably doesn't have enough ports to handle it all. You don't have to replace your peripherals with new gadgets that can connect wirelessly.
Instead, invest $9 into this Aukey 4-Port USB Hub and do more with the space you already have. It typically costs around $13, but applying coupon code NIQOETMK during checkout will drop your total to $9.09. That's on par for the best deal we've seen for this hub. It hasn't gone on sale very often since it was first released, either. You can use Amazon Prime or spend at least $25 to avoid shipping fees.
This slim USB hub turns a single USB-A port into four of them. It supports data transfers, too, with speeds up to 5Gbps. That's fast enough to transfer an HD movie in just a few seconds. The solid aluminum alloy housing helps dissipate heat, which is a nice bonus since adapters like these have a reputation for heating up quickly and cooling down slowly. It has a slim footprint, so it won't take up too much room on your desk either. Aukey includes a 45-day money-back guarantee as well as a 24-month warranty with your purchase. Users give it 4.4 out of 5 stars on average.
A hub like this provides spaces for your phone charger, Bluetooth mouse receivers, flash drives, and much more. It's important to note that it connects via USB-A, though, so some laptops aren't going to be compatible with it. If you're stuck with just a couple of USB-C ports, consider this USB-C adapter instead. It's on sale for $22 for a limited time.
Be an expert in 5 minutes
Louryn saves money on everything she buys (which is a lot.) In between waiting for Amazon deliveries, she pines for the next Elder Scrolls installment and checks Reddit for gaming rumors. She also loves Hearthstone, makeup, and beer. Find her on Twitter: @lourynstrampe
