Charge your phone while keeping it safe in the car using this $12 mount
There are a few travel essentials everyone should keep in their vehicle. Once you've stashed a flashlight and a portable jump starter in the glovebox, the next items you'll want to pick up are a USB car charger and a phone mount. Rather than paying for them separately, you can score both at a discount with Kuulaa's Qi Certified Wireless Charging Car Mount. This car mount wirelessly charges Qi-compatible devices so you won't even have to worry about plugging your phone in when you get inside your vehicle, and today you can pick one up at Amazon for just $12.49 when you enter promo code PG36X53S during checkout. That saves you a full 50% off its current price of $25 there, and it's also a match of the best price we've ever seen it reach.
Kuulaa Right-Angled USB-C Cable, 2-pack
$6.30 $13.99 Save $8
Kuulaa's USB-C cables are each 3.3-feet long, suitable for charging and data transfers, and down to around $3 apiece using the following promo code at Amazon. That code also works for the 6.6-feet cables, taking $10 off.
Kuulaa 10W Qi Wireless Charging Stand
$10.99 $19.99 Save $9
This stand offers up to 10W fast charging for compatible devices, along with safety protections to keep your phone safe from overcharging, overheating, and more.
Kuulaa Wired Headphones
$4.39 $10.99 Save $7
Sometimes, you just need the wires. These headphones have an in-line mic so you can make and receive phone calls, and offer a powerful yet balanced sound for listening to music. Clip the on-page coupon and use the promo code at checkout.
Rock Right-Angled USB-C Cable (2-pack)
$6.99 $13.98 Save $7
The unique design allows the cable to sit behind your phone as it charges so you can keep using it without holding it in an odd position. Use the code on either the 3.3ft or 6.6ft version to score either 2-pack at 50% off.
$11.54 $19.99 Save $8
This Qi wireless charging stand charges compatible devices at up to 10W and can even charge through phone cases. You'll just need to enter the following code at checkout to score this low price.
This wireless charging car mount can power compatible devices at up to 10W and uses a clip to mount onto your vehicle's air vent. That means you won't have to worry about it blocking your line of sight while driving either. It features an aluminum alloy base along with a soft silicone pad to keep your phone from sliding off or being scuffed up. Simply mount your phone and get going. You won't need to worry about removing your phone's case as this mount can charge through cases up to 5mm thick.
The included USB car charger you'll receive features Quick Charge 3.0, and you'll also score a micro-USB cable with this purchase as well as a one-year warranty. With its integrated smart chip, this wireless car charger keeps your devices protected from overcurrent, overvoltage, and overheating.
Shipping at Amazon is free on orders totaling $25 or more, or with an Amazon Prime membership. If you're not a member already, consider starting a free 30-day trial to score free two-day shipping with no order minimum, exclusive members-only discounts, and more.
