This discounted USB car charger doubles as a Bluetooth FM transmitter for just $12
Adding Bluetooth to your vehicle doesn't require an expensive trip to the dealership. Today, you can grab Anker's Roav SmartCharge F0 dual-USB port Bluetooth FM transmitter on sale for only $12.23 on Amazon. Simply clip the coupon on its product page to snag this low price and save nearly $5 instantly. The Roav normally sells for around $17, and today's deal is one of the best prices it's ever reached.
Anker Soundcore Life Q30 hybrid active noise-cancelling Bluetooth headphones
$59.99 $79.99 Save $20
These hybrid Bluetooth headphones reduce ambient noise up to 95% thanks to active noise-cancelling mics. The battery lasts up to 40 hours with ANC on or 60 hours with it off, and recharge via USB-C. Clip the $20 on-page coupon.
Anker Powerline II 6-feet USB-C to Lightning cable
$12.74 $15.00 Save $2
When using a USB-C power adapter (not included), you'll get the fastest possible charge for your iPhone. Plus you can seamlessly sync and charge your Mac. This is Apple MFi certified and lasts 12 times longer than other cables.
Anker Liberty Air 2 Pro true wireless earbuds Best Buy
$79.99 $130.00 Save $50
These earbuds have active noise-cancelling that's customizable with a simple app. You'll get a total of 26 hours of playtime with seven hours from a single charge and the rest from the charging case. Uses USB-C and has wireless charging.
Anker Soundcore Rave Neo portable Bluetooth speaker with LED lights
$84.99 $120.00 Save $35
Includes a rechargeable battery that will last for up to 18 hours and can charge other devices with the USB port. IPX7 rated for water resistance. The built-in LED lights will sync to the music you're playing. Connect multiple speakers together.
Anker Soundcore Liberty 2 Pro true wireless earbuds black
$49.99 $100.00 Save $50
They last for up to eight hours on a single charge with up to 32 hours total using the charging case. They have quick charge so you can get two hours after 10 minutes spent charging. They also charge via USB-C or a Qi wireless charger.
Using this device, you'll be able to stream music from your phone straight to your car's sound system with solid Bluetooth and FM connections. All you need for FM is an unoccupied radio station, and the Roav's boosted signal and static-cancellation tech will do the rest to provide you a clear way to listen to your favorite tunes. The two USB ports provide simultaneous high-speed charging so you can keep your phone powered up on the way to your destination. You'll also get echo cancellation and a stable connection when using the Roav for phone calls while using its built-in microphone.
This Bluetooth FM Transmitter comes with a one-year warranty. Users give it 4.5 stars based on over 5,000 reviews. A few cars won't be compatible with this device, so be sure to check the list on the product page at Amazon before checking out.
Having a USB car charger in your vehicle is pretty important, but it's not the only essential on sale today. You can also pick up the Vantrue N1 Pro Dash Cam on sale for just $51.99 when you clip its on-page coupon and then use promo code NSK8EBFW during checkout.
Shipping at Amazon is free on orders totaling $25 or more, or with an Amazon Prime membership. If you've never been a member before, you can start a free 30-day trial to score free two-day shipping with no order minimum, along with access to perks like the Prime Video streaming service, exclusive members-only discounts, and more.
