This discounted 30W USB-C wall charger supports Power Delivery and Quick Charge for $24
Anker's slimmest Power Delivery charger is a perfect match for hard-to-reach outlets hidden behind furniture. It's just over half an inch thick and charges devices super fast thanks to its USB-C port that supports Qualcomm Quick Charge and USB-C Power Delivery. Though it normally sells for $35, today you can snag one for only $23.99 at Amazon. You'll be saving $11 and a lot of time in the process.
Anker Soundcore Life Q30 hybrid active noise-cancelling Bluetooth headphones
$59.99 $79.99 Save $20
These hybrid Bluetooth headphones reduce ambient noise up to 95% thanks to active noise-cancelling mics. The battery lasts up to 40 hours with ANC on or 60 hours with it off, and recharge via USB-C. Clip the $20 on-page coupon.
Anker Powerline II 6-feet USB-C to Lightning cable
$12.74 $15.00 Save $2
When using a USB-C power adapter (not included), you'll get the fastest possible charge for your iPhone. Plus you can seamlessly sync and charge your Mac. This is Apple MFi certified and lasts 12 times longer than other cables.
Anker Liberty Air 2 Pro true wireless earbuds Best Buy
$79.99 $130.00 Save $50
These earbuds have active noise-cancelling that's customizable with a simple app. You'll get a total of 26 hours of playtime with seven hours from a single charge and the rest from the charging case. Uses USB-C and has wireless charging.
Anker Soundcore Rave Neo portable Bluetooth speaker with LED lights
$84.99 $120.00 Save $35
Includes a rechargeable battery that will last for up to 18 hours and can charge other devices with the USB port. IPX7 rated for water resistance. The built-in LED lights will sync to the music you're playing. Connect multiple speakers together.
Anker Soundcore Liberty 2 Pro true wireless earbuds black
$49.99 $100.00 Save $50
They last for up to eight hours on a single charge with up to 32 hours total using the charging case. They have quick charge so you can get two hours after 10 minutes spent charging. They also charge via USB-C or a Qi wireless charger.
This high-speed USB-C wall charger can power up a 12-inch MacBook from 0% to 100% in just two hours. It doesn't come with a USB-C cable, so you'll want to make sure you have one handy when it arrives. However, Anker does include an 18-month warranty in case you experience any issues with its use. To keep it compact, Anker equipped this charger with a foldable plug and designed it to be 35% smaller than the comparable, yet much more expensive 60W Apple MacBook charger.
If you don't have a USB-C cable ready to use at home currently, this guide to the best USB-C cables of 2019 has several durable options to consider. Adding one to your cart before checking out would even help you score free shipping on this order if you're not a Prime member.
Shipping at Amazon is free on orders totaling $25 or more, or with an Amazon Prime membership. If you've never been a member before, you can start a free 30-day trial to score free two-day shipping with no order minimum, along with exclusive members-only discounts, access to the Prime Video streaming service, and more.
Be an expert in 5 minutes
