This discounted power strip features surge protection and USB ports for less than $15
How many power strips do you have at home that only feature AC outlets? We charge so many devices via USB these days, so why not have a power strip with USB ports on it? They're affordable, dependable, and today you can snag the Teckin Desktop Surge Protection USB Power Strip at Amazon for only $14.67 when you enter promo code DI9YIG3N during checkout. That saves you a little bit over $4 off its price there, though it's recently sold for up to $20. Today's deal brings this power strip lower than it's ever reached without a code before, so you don't want to pass up this opportunity.
Teckin Smart Dimmable Standing LED Floor Lamp
$59.49 $69.99 Save $10
Teckin Under Cabinet Lighting 3-Pack
$10.48 $18.99 Save $9
Teckin European Travel Plug
$10.87 $16.99 Save $6
Instead of buying multiple adapters, save money with this 5-in-1 European travel plug. Just enter the below code to make $6 off its regular price.
Teckin Smart Plug 4-Pack
$25.99 $39.99 Save $14
If your old tech could use an update, smart plugs are one of the easiest ways to get it done.
Teckin E27 Multicolor Smart Light Bulb 2-Pack
$19.99 $24.99 Save $5
At just a dollar more than the best price we've seen per bulb, this is a great way to add to your smart home and save some cash while you do it.
With its three USB charging ports and three AC outlets, you'll be able to provide power to up to six devices and appliances at once. It's protected from overloads and has a safety snap button which automatically pops up and cuts off the power when the load power has exceeded the rated power.
This power strip's compact, lightweight design also makes it a good fit to keep just about anywhere. Rather than on the floor or hidden behind furniture, you could keep it placed on your desk or nightstand for easy access without it being a bulky eyesore or taking up too much space. There are also four non-slip rubber feet on its bottom which help keep it from sliding around.
Teckin's power strip features a five-foot extension cord, though if you need to place it somewhere farther away, you could add an exension cord to your cart to ensure you can plug it in anywhere around your home. That would also help you reach Amazon's $25 order minimum needed for free shipping. Otherwise, you can also have your order shipped for free with Amazon Prime. Teckin includes a 12-month warranty with this purchase.
If you're on the hunt for a power strip that you can control with your smartphone, you'll want to look into our guide to the best smart surge protectors in 2019.
