This discounted Philips Hue Smart LightStrip Plus comes with a 40" extension kit for $52
Switching up the vibe of any room is much simpler when you have lights like the Philips Hue LightStrip installed. These dimmable LED smart lights can be controlled using an app on your phone and can change to over 16 million colors at your command. They're not the most inexpensive light strips out there, and you need a Hue Hub for them to work properly in your home, but considering that Woot has a bundle with the 80-inch Philips Hue LightStrip Plus and the 40-inch Extension Kit on sale for just $51.99 today only, now's a better time than most to make the purchase. While the items being offered are factory reconditioned models and not brand new, they've each been inspected and tested directly by Philips to ensure they're in proper working order and like-new condition. Woot even includes a 90-day warranty with the purchase.
Brand new models of Philips' Hue LightStrip Plus normally sell for up to $80 on Amazon, while the extension kit can regularly be found for $25. With that in mind, today's deal saves you more than 50% off what they'd cost separately, and you likely won't be able to tell much difference between the ones you receive and new models. Woot offers free shipping to anyone who signs in with an Amazon Prime account; otherwise, you'll pay a $6 shipping fee, so you might want to start a free 30-day Prime trial to keep the cost down.
Philips Hue Refurbished Smart Home Sale
Prices Vary
Today only, Woot is holding a sale on refurbished Philips Hue smart home products, from smart bulbs and strip lights to the Philips Hue bridge which makes them all work together. A 90-day warranty is included, too.
Philips Hue White & Color Ambiance Signe table lamp (Requires Hue Hub, Works with Amazon Alexa, Apple HomeKit and Google Assistant)
$114.97 $159.99 Save $45
Philips Hue Starter Kit with Dimmer Switch
$104.95 $99.99 Save $-5
$159.99 $159.99 Save $0
With the 80-inch Philips Hue LightStrip Plus smart light, you'll have over six feet of smart lighting to play with, while the included Extension Kit adds another 3.3 feet for a total of 10 feet of lighting. You can use the Philips Hue app to control them as a pair and change their color even when you're not at home, or ask a device with Amazon Alexa to help you out, such as the Echo Dot.
To add even more affordable smarts to your home, take a look at our list of best smart home products under $100 once you're done checking out at Woot.
