Dell's 27-inch 1440p monitor has matched its lowest price on Amazon at $275
The Dell S2719DGF S-Series 27-inch 1440p monitor is down to $275.49 on Amazon. This price matches the lowest we have ever seen on Amazon, and it has only hit this low once before. The deal is matching a price through Dell's website, and that is only going to good for as long as the Dell President's Day sale continues. If you want this monitor, you'll want to act fast. The monitor regularly sells for around $300 or more, and you can find it going for that price at retailers that aren't matching Dell, like Best Buy.
If you're a gamer or spend a lot of time in front of your computer and just want one all-around great monitor, this is it. The Dell 27-inch has 2K Quad HD 2560 x 1440 pixel resolution, a 1 ms response time, and a 144 Hz refresh rate. If you connect through the DisplayPort, you can overclock the monitor to a 155 Hz refresh rate, but you'll get up to 144 Hz even if you just connect through the HDMI 2.0 port.
The connectivity options include two HDMI ports, one DisplayPort, and a USB hub with four USB 3.0 ports. Hubs like that are really nice for getting all your peripherals plugged in, especially if your desktop doesn't have a huge amount of ports in the back.
Despite being a TN panel, which usually means sacrificing viewing angles for faster response times, it has viewing angles up to 170 degrees. That means you can still watch your media even from different vantage points around the screen.
The monitor also has adaptive sync, which reduces screen tearing during high-performance moments. The default tech is AMD's FreeSync, but it is also compatible with Nvidia's G-Sync tech. In order to get it to use that you'll need to connect via DisplayPort and have a Nvidia graphics card from the 10xx or 20xx series.
Be an expert in 5 minutes
