Dell's 27-inch 2K gaming monitor with 155Hz refresh rate is on sale for $285
The Dell S2719DGF 27-inch LED FreeSync monitor has dropped to $284.65 on Dell's website. The last deal we shared on this monitor was when it dropped to around $300, and you can still find it for that price at a few retailers like Amazon. For the moment, however, Dell is beating both of them with a price it matched once before back in May. And we know it's going for as much as $400 at places like B&H.
If you're a gamer or spend a lot of time in front of your computer and just want one all-around great monitor, this is it. The Dell 27-inch has 2K Quad HD 2560 x 1440 pixel resolution, a 1 ms response time, and a 155 Hz refresh rate. The connectivity options include two HDMI ports, one DisplayPort, and a USB hub with four USB 3.0 ports. It has viewing angles up to 170 degrees, along with AMD's FreeSync tech to reduce screen tearing. The monitor is also compatible with Nvidia's G-Sync tech if you're using a 10 or 20 series graphics card and connect to it over DisplayPort.
Be an expert in 5 minutes
