Cowin E7 vs Cowin E7 Pro: Which should you buy?
Cowin E7
The regular Cowin E7 have just about everything you could want in a pair of mid-range headphones. They have a good sound, active noise cancelation, and reliable battery life. For the price, these are a steal.
Cowin E7
Reasons to buy
Reasons to avoid
Cowin E7 Pro
For a few more dollars, you can step up to the Cowin E7 Pro. The headphones are mostly the same, but for a few more dollars, you get slightly improved noise cancelation and larger speaker drivers for more powerful sound.
Cowin E7 Pro
Reasons to buy
Reasons to avoid
Both the Cowin E7 and E7 Pro are worth a look if you're shopping for Bluetooth headphones under $100. The regular E7 are probably fine for most people, as the differences compared to the E7 Pro are negligible at best. However, if you do have a few extra dollars to spend and want a slightly better all-around experience, the E7 Pro won't let you down.
Cowin E7 vs. Cowin E7 Pro Price and availability
As the names of the two headphones suggest, the Cowin E7 is the more affordable option while the E7 Pro gets hit with a higher price for more premium features.
The regular Cowin E7 retails for around $60 for the black model, with other color options increasing the price by a few dollars. It's a similar story for the Cowin E7 Pro, which starts at $80 and goes up if you want a color that's not black.
Both headphones are readily available for purchase at Amazon and Walmart, so buying one shouldn't be a challenge.
Cowin E7 vs. Cowin E7 Pro Most people can stick with the regular E7 headphones
If you've ever shopped around for budget Bluetooth headphones, chances are you've come across the Cowin E7 once or twice. These have become one of the most popular options in this price range, and for most people, the E7 is the way to go when compared with its slightly more expensive sibling.
Be an expert in 5 minutes
As you can see from the spec sheet below, the E7 and E7 Pro have a lot in common. Both pairs of headphones have active noise cancelation, Bluetooth 4.0, a 3.5mm jack for wired listening, and up to 30 hours of battery per charge.
The sound quality on the E7 won't knock your socks off, but it's more than good enough whether you want to listen to music, tune in to your favorite podcast, or watch a YouTube video. The presence of ANC is also fantastic, especially at this price.
The plastic build of the Cowin E7 is perhaps the weakest aspect, but that's the only real downside we can think of. Thankfully, the vast selection of colors helps to make up for this.
Header Cell - Column 0 | Cowin E7 | Cowin E7 Pro |
Active Noise Cancelation | ✔️ | ✔️ |
Noise Reduction Depth | 28db | 30db |
Connectivity | Bluetooth 4.0NFC3.5mm jack | Bluetooth 4.03.5mm jack |
Sound | 40mm large-aperture drivers | 45mm large-aperture drivers |
Battery | 30 hours | 30 hours |
Cowin E7 vs. Cowin E7 Pro What you get with the E7 Pro
If the Cowin E7 headphones are so good, what's the point of spending more money for the E7 Pro? While the differences aren't that stark, they might be enough for some potential buyers to pull the trigger.
The E7 Pro offers slightly better noise cancelation, with them being able to reduce up to 30db of noise while the regular E7 max out at 28db. You'll also get bigger, more powerful sound with the larger 45mm drivers.
Lastly, while the E7 Pro also feature a plastic construction, we favor their overall aesthetic just a little more. That's entirely subjective, however, so take it as you will.
Super-affordable, super-powerful
In the budget headphone space, the Cowin E7 stands out as one of the better options. While the plastic design isn't anything special, we love the excellent sound quality, active noise cancelation, and 30-hour battery. Factor in the price, and you're getting a heck of a deal.
Upgrade your sound for a few extra dollars
The Cowin E7 Pro have a lot in common with the regular E7, but for a few dollars more, you can upgrade to better noise cancelation and more powerful audio. Not everyone needs to make this upgrade, but if you're financially able to, it's worth considering.
Joe Maring was a Senior Editor for Android Central between 2017 and 2021. You can reach him on Twitter at @JoeMaring1.
