Even if you spent a ton of money during the holiday season, you can still afford to pick up this iClever fast wireless charger at Amazon. With code JODNJCJB, it drops to just $6.99 at checkout. That's half off and makes it cheap enough to add on to your desk or nightstand, or both. This matches the lowest we've ever seen it go.
iClever 61W Power Delivery 3.0 USB-C Wall Charger
$15.35 $26.99 Save $12
iClever 10W Qi-compatible wireless car charger with automatic clamp
$24.14 $37.00 Save $13
Stack the coupon code with the on-page coupon for maximum savings. Includes automatic infrared sensor that detects phone and works even when the car is off. Compatible with all Qi-enabled wireless charging phones and provides up to 10W power.
Wireless charging has become almost ubiquitous in recent years with the majority of flagship and mid-range phones featuring Qi charging these days. There are tons of wireless chargers on the market, too, but not all of them are made equal.
This option from iClever is a fast wireless charger. That means it can power up supported Android phones at 10W and iPhone models at 7.5W so you can go from empty to full more quickly. The charger even works through phone cases as long as it is less than 6mm thick and not made of metal, both of which will interfere with the wireless charging process. There's a non-slip silicone ring on top of the charger to keep your phone in place, even if it vibrates for incoming notifications, and there's a soft LED on the front letting you know your phone is placed correctly and charging. The charger itself is constructed in a way that helps dissipate heat efficiently and there are built-in safeguards to protect from over-charging, short-circuiting, and power surges.
Existing owners rate this charger highly with an average score of 4.1 out of 5 stars at Amazon. It's worth noting that this charger does not come with a wall plug so you'll have to provide your own, or pick up a spare.
