The Corsair K70 Mk.2 mechanical keyboard on sale for $100 has a sleek low profile design
Step up to a super powerful but also surprisingly quiet mechanical gaming keyboard. The Corsair K70 RGB Mk.2 Rapidfire low profile Cherry MX Speed mechanical keyboard is down to $99.99 on Amazon. This is a Best Buy price match, so the deal might disappear at any moment. The keyboard can sell as high as $170 and more often sells for around $140, but either way the drop to $100 is one of the lowest we've ever seen.
Corsair K95 Platinum Cherry MX Speed RGB mechanical keyboard
$119.99 $200.00 Save $80
Full-size keyboard with Cherry MX Speed mechanical switches. Includes six one-touch keys you can program to do anything you want. Create custom macros with the 18 programmable G Keys. Includes a USB passthrough port and a palm rest.
Corsair K95 RGB Platinum XT mechanical gaming keyboard
$159.99 $200.00 Save $40
Not for the faint of heart. This thing uses Cherry MX Speed XT Silver switches. Has full RGB on individually backlit keys with a 19-zone LightEdge on the top. Has precision-molded keycaps, six programmable macro keys, and a leatherette palm rest.
Corsair K95 RGB Platinum mechanical gaming keyboard gunmetal
$109.99 $160.00 Save $50
Full keyboard with six one-touch hot keys for instant access to internet, email, volume controls, and more. Uses Cherry MX Speed mechanical switches. Has 18 programmable G keys and USB passthrough ports. Comes with palm rest, too.
Corsair K57 RGB wireless gaming keyboard
$79.99 $90.00 Save $10
Includes Corsair's Slipstream wireless for sub-1ms low-latency Bluetooth. Also go USB wired. Get per-key RGB backlighting and six programmable macro keys. Includes a detachable soft rubber palm rest and dedicated volume and multimedia controls.
Corsair iCue Commander Pro smart controller for RGB lighting and fan speed
$58.82 $75.00 Save $16
Turn any PC case into a smart case and use Corsair's iCue software to control up to six case fans and two RGB lighting channels. Two USB 2.0 internal headers let you connect internal USB devices. Monitor temperatures and your whole system.
Corsair's K70 Mk.2 keyboard uses a low profile design that means the keys don't travel as far, and the Cherry MX Speed switches are designed for a smooth, linear experience with only a 1.2mm actuation. The slim design is new and lets you fit this keyboard in just about any desktop setup. There are advanced macros and light programming options, which you can customize with Corsair's easy-to-use software. It also has a USB pass-through port for additional USB access for a mouse or headset.
