Corsair's renewed HS70 SE Wireless Gaming Headsets can save you 65% off the full cost
Amazon has renewed models of the Corsair HS70 SE Wireless Gaming Headset on sale for just $34.99 today. This deal saves you $15 off the refurb's regular cost, while brand new they can sell for up to $100. These headphones have each been inspected, tested, and cleaned to ensure they're in like-new condition, and they even come with a 90-day warranty.
Corsair K95 Platinum Cherry MX Speed RGB mechanical keyboard
$119.99 $200.00 Save $80
Full-size keyboard with Cherry MX Speed mechanical switches. Includes six one-touch keys you can program to do anything you want. Create custom macros with the 18 programmable G Keys. Includes a USB passthrough port and a palm rest.
Corsair K95 RGB Platinum XT mechanical gaming keyboard
$159.99 $200.00 Save $40
Not for the faint of heart. This thing uses Cherry MX Speed XT Silver switches. Has full RGB on individually backlit keys with a 19-zone LightEdge on the top. Has precision-molded keycaps, six programmable macro keys, and a leatherette palm rest.
Corsair K95 RGB Platinum mechanical gaming keyboard gunmetal
$109.99 $160.00 Save $50
Full keyboard with six one-touch hot keys for instant access to internet, email, volume controls, and more. Uses Cherry MX Speed mechanical switches. Has 18 programmable G keys and USB passthrough ports. Comes with palm rest, too.
Corsair K57 RGB wireless gaming keyboard
$79.99 $90.00 Save $10
Includes Corsair's Slipstream wireless for sub-1ms low-latency Bluetooth. Also go USB wired. Get per-key RGB backlighting and six programmable macro keys. Includes a detachable soft rubber palm rest and dedicated volume and multimedia controls.
Corsair iCue Commander Pro smart controller for RGB lighting and fan speed
$58.82 $75.00 Save $16
Turn any PC case into a smart case and use Corsair's iCue software to control up to six case fans and two RGB lighting channels. Two USB 2.0 internal headers let you connect internal USB devices. Monitor temperatures and your whole system.
The HS70 is certified for use with Discord and features adjustable plush memory foam earcups with precision-tuned 50mm Neodymium speaker drivers. The headset can connect to devices wirelessly from up to 40 feet away and last for up to 16 hours on a single battery charge. Its microphone is fully detachable making it easy to store and keep intact too. As it connects using a USB dongle, it will be compatible with PCs and the PlayStation 4 console, and you'll be able to get virtual surround sound on the PC.
