Make your outdoor appliances smart with iClever's weather-resistant plug on sale for $20
The iClever IC-BS06 outdoor Wi-Fi smart plug is down to $19.99 at Amazon. That's a solid $6 off its regular price and a match for the best direct price drop we've ever seen. Considering how popular these plugs are, they don't tend to go on sale very often at all. Grab a couple if you like putting up some outdoor lights or already have some outdoor appliances you want to control without going outdoors.
iClever 61W Power Delivery 3.0 USB-C Wall Charger
$15.35 $26.99 Save $12
iClever 10W Qi-compatible wireless car charger with automatic clamp
$24.14 $37.00 Save $13
Stack the coupon code with the on-page coupon for maximum savings. Includes automatic infrared sensor that detects phone and works even when the car is off. Compatible with all Qi-enabled wireless charging phones and provides up to 10W power.
This outdoor plug is hazard proof so you don't have to worry about it or the devices connected to it. There's even built-in surge protection in case of a power surge and safety features to protect from things like overheating. Whether you're really into holiday lighting or planning to host a party on your deck, the plug can be used to power all your lights and appliances outdoors. It is IP44 rated, which means you don't have to worry about things like sticks or even ants getting into the outlets and frying them, either.
With the smart functionality, you don't even have to leave the house to control whatever is plugged in. The plug comes with a free app called iClever Smart Home you can download. From there, you can program the plug to do what you want. Add it to your Amazon Alexa or Google Assistant for voice controls, which means you can command the plug from anywhere in the home with just your voice. It also works with IFTTT.
The app can also be used to set up routines or automatic timers. Set your lights to come on before you get home from work. Set them to turn off during the day. Turn one light on at one time and another light on at another. Make it look like you're always home even when you're not.
