Control your garage door from your phone with the Meross smart opener on sale for $28
You are now subscribed
Your newsletter sign-up was successful
Stack the coupon code ZLUINGM5 with the 5% off on-page coupon to get the Meross smart Wi-Fi garage door opener remote down to $28.43 through Amazon. This is a great low price, and it even beats out a sale we saw a week ago that featured a selection of Meross products up to 40% off. In that sale, the same garage door opener was going for a little less than $31. It more regularly sells at $50, actually, so the double discounts are actually just adding onto an already decent price drop showing it at $38. Think of that like triple discounts all stacked together to give you some awesome savings.
Meross dual outlet smart plug 2-pack
$25.99 $34.00 Save $8
Create two outlets with one plug and a compact design that won't block the other socket. Control the plugs and the devices plugged into them with the Meross app. Or use Apple HomeKit, Amazon Alexa, or Google Assistant for voice control.
Meross dimmable multi-color Wi-Fi smart table lamp
$26.99 $45.00 Save $18
The intuitive touch controls on top let you change the color, adjust the brightness, and turn it on or off. Also works with Siri, Alexa, and Google Assistant for voice control. Includes several levels of tunable white and 16 million colors.
Meross Smart Wi-Fi Garage Door Opener
$26.79 $40.00 Save $13
Combine the code with the $10 off on-page coupon for maximum savings. Adds remote and voice control easily to your existing garage door opener and doesn't require any extra hub. Easy to set up with included tools. Get notifications and reminders.
$26.79 $39.99 Save $13
This garage door opener lets you control it using an app on your phone, or even with your voice and a compatible voice assistant like Amazon Alexa. Clip the coupon on its product page and use the following promo code to save $13 at checkout.
$49.99 $59.99 Save $10
The original Meross smart garage door opener was simply the result of a successful crowdfunding campaign on the website Indiegogo back in 2018. Since then, Meross has become a great company for simple smart home products.
The garage door opener adds remote and voice control easily to your existing garage door opener and doesn't require any extra hub or anything like that. It's compatible with both Amazon Alexa and Google Assistant, and you can use the Meross app to turn your phone into a garage door remote control. This is great if you manage to get all the way to work only to remember you left it open. It's also a way to let in guests, forgetful children, and others when you can't get to the door.
You can get notifications that let you know whether the door is opened or closed, overnight notifications that help remind you to close it, and more. It comes with strong adhesive that you use to install it, making the entire set up process quick and painless.
The device has a high-sensitivity sensor that monitors the status of the garage door and always stays stable. It's also very easy to install and comes with the tools you need to do so.
