Control your entire entertainment system with the Logitech Harmony 950 down to $175
Time to unite all your entertainment devices with one remote to rule them all. The Logitech Harmony 950 infrared touch remote control is down to $174.99 on Amazon. This is just Amazon price matching Best Buy's deal of the day, which also has the Harmony 950 for this price through Best Buy's eBay store and the main site. The Harmony 950 regularly sells for around $200 and sometimes goes as high as $250. The drop today is one of the lowest we've ever seen.
Logitech G Pro X Superlight wireless gaming mouse
$137.98 $150.00 Save $12
This mouse was made in collaboration with leading esports pros,, which means it's designed with intense and competitive gaming in mind. It weighs less than 63 grams. The Hero Sensor is designed for best possible performance.
Logitech G640 large cloth gaming mousepad black
$24.99 $40.00 Save $15
Gives the right amount of resistance to your mouse with low DPI gaming so you can be more precise. Surface provides a consistent texture for an even translation of mouse to cursor movement. Rubber bottom keeps it from slipping.
Logitech G613 Lightspeed wireless mechanical gaming keyboard black
$63.99 $79.00 Save $15
Includes Bluetooth and Logitech's Lightspeed wireless tech for a 1ms report rate. Uses Romer G mechanical switches that are very durable and can survive 70 million clicks. Has six programmable G keys and lasts up to 18 months on two AA batteries.
Logitech G305 LightSpeed wireless gaming mouse
$39.99 $60.00 Save $20
Includes Logitech's wireless USB receiver for a speedy connection. LightSpeed tech makes the responsiveness less than 1 millisecond. Includes a 12,000 DPI sensor, 250 hours of battery life, LED optical scanning, 6 programmable buttons, and more.
Logitech G502 Hero high performance gaming mouse black
$39.99 $50.00 Save $10
Uses high-performance 16K DPI sensor. Huge adjustable range as well. Has 11 customizable buttons with onboard memory so you can store different combinations per game. Has RGB lighting and LightSync to pair with other gear.
The all-in-one remote features a 2.4-inch touchscreen with settings that allow you to power on and off multiple devices in a single touch. You can even set up one-touch activities like "Watch a movie" that will automatically power on and switch to the right devices with the right settings. The remote's keys all come with backlighting that's activated by motion, so you don't have to go fumbling to press the correct buttons in the dark. It comes with a charging station to keep it powered up and is compatible with over 270,000 devices. You'll be able to control your TV, cable box, Apple TV, Blu-ray player, and even your game console all with this one remote; it can be connected to up to 15 devices simultaneously, so you don't have to go digging for that lost controller.
Logitech Harmony has an extensive lineup, too. If you want a similar remote that also includes a smart hub and works with your smartphone, try the Logitech Harmony Elite. It includes a touchscreen remote similar to the 950, a hub that works even behind closed cabinets, and it communicates with an app you can download on iOS or Android.
