Conserve water and save money with the Flo by Moen smart system on sale for $399
Moen Flo
Moen Flo (Image credit: Amazon)
The Flo by Moen 3/4-inch smart water shutoff has dropped to $399 on Amazon. This smart water system is actually on sale thanks to Home Depot's Special Buy of the Day, and Amazon is just price matching. Get it at either retailer but just know this price is temporary. It normally sells for $499 or more in both places and hasn't dropped this low since August last year.
Moen 900 Flo Leak Detection Smart Home Water Security System, Alexa-Enabled
$391.37 $398.02 Save $7
Moen 7565SRS Align One-Handle Modern Kitchen Kitchen Pulldown Faucet with Reflex and Power Clean Spray Technology, Spot Resist Stainless
$294.00 $319.74 Save $26
$380.00 $398.02 Save $18
$390.00 $447.23 Save $57
Moen 7594SRS Arbor One-Handle Pulldown Kitchen Faucet Featuring Power Boost and Reflex, Spot Resist Stainless
$198.84 $290.12 Save $91
Use the Moen Flo to get 24/7 protection for your home. The system is already designed to turn your water off automatically to protect your home from water damage, but you can also turn it off manually using the app. That means you can turn your water off from anywhere, even if you drive to work and suddenly remember you left something running.
The system's Micro Leak Technology helps identify leaks as small as a drop and keeps an eye on your home's whole water system, including behind walls. FloSense technology analyzes your home's use of water and provides you a uniquely optimized use of water. You can see all this stuff through the app's dashboard, which also helps you set goals for conserving water.
Use the system with smart home ecosystems including Amazon Alexa, Google Assistant, and other stuff like IFTTT without the need for an additional hub.
