Clean your home on command with this smart robotic vacuum at nearly 35% off
Time is money, and you'd probably have more of both if you didn't have to spend all afternoon cleaning some days. With the Opodee Robotic Vacuum Cleaner, you can cut down on the time and money spent by clipping the coupon on its product page at Amazon and then entering promo code H2JVG557 during checkout. Together, the two drop its price to $172.99 saving you $87 now and even more later once it gets to work in your home.
Opodee's robotic vacuum lets you use an app on your phone to control its movements or schedule cleanings, and you won't even need to be home to do so. Since it's compatible with Amazon Alexa, you'll also be able to voice control it if you have a compatible Echo device.
This robotic vacuum cleaner features a powerful 1800Pa suction along with five cleaning modes such as Spot Cleaning, Edge Cleaning, and Single Room. There's also a built-in gyroscope that helps the vacuum navigate your home without missing a spot, and thanks to its height of less than 3 inches, it can glide under furniture and catch all the dust bunnies that have been hiding. It's pet-friendly and has a high-efficiency air filter to trap dust and other allergens.
Powered by a 2500mAh rechargeable battery, this vacuum can keep cleaning for up to 100 minutes on a single charge and then rolls itself back to its charging station when it's time to power up again. It's even equipped with 360-degree anti-collision and drop sensors to keep it from falling down stairs or crashing into furniture. Boundary strips and a remote are included with its purchase.
Amazon offers free shipping on this robotic vacuum, though you'd recieve your order even faster with Amazon Prime. If you're not already a member, consider starting a free 30-day trial to score free two-day shipping, exclusive members-only discounts, and more.
Be an expert in 5 minutes
