Clean those pearly whites with the Philips Sonicare electric toothbrush down to just $80
Sometimes Amazon gets a little over-aggressive in the price matching department, and I think that's the case here. This deal might actually be a mistake that's pricing the Philips Sonicare electric toothbrush too low because it's down to $79.99 on Amazon when you clip the on-page coupon. You can find a similar $20 off coupon at Target but the toothbrush is $150 there. Best Buy is discounting the toothbrush to $99.99 as part of the Deals of the Day but not taking an extra $20 off. Amazon has combined both deals to give you the ultimate best price and probably did it on accident. Don't be surprised if one of those discounts disappears sooner or later. This is a toothbrush that normally sells for around $150 and was going for as much as $200 before the holiday shopping season.
Philips SmartSleep wake-up light
$79.95 $100.00 Save $20
Simulates the sunset and sunrise and includes 5 different wake-up sounds. Has an FM radio with snooze and automatic dimmable display. It also includes 10 brightness settings. Help establish a healthy sleeping and waking routine.
Philips Hue white & color BR30 starter kit
$69.99 $120.00 Save $50
The kit includes two multicolor BR30 smart bulbs and the Philips Hue bridge designed to help you unite your bulbs and connect them to your Wi-Fi network. Find the perfect lighting with preset scenes or lighting effects that sync to your movie.
Philips Audio Fidelio X2HR over-ear open-air headphones
Up to 20% off
The X2HR have Hi-Res Audio with 50mm high-def neodymium drivers and an acoustic open-back architecture. They have deluxe memory foam ear pads and a lightweight adjustable hammock with genuine leather.
Philips SmartSleep Connected sleep and wake-up light therapy lamp
$169.99 $200.00 Save $30
Built-in bedroom sensor and smartphone connection helps create ideal environment. AmbiTrack sensor measures your bedroom's temp, noise, light, and humidity. Customize the alarm, light, sound, and sunrise/sunset themes. Has clock and touch display.
Philips goLITE BLU Rechargeable Energy Light
$130.40 $137.79 Save $7
Do you brush your teeth as long as you should? Do you go the full two minutes? Probably not. It's hard. Two minutes is a long time. Especially early in the morning when you're not quite awake and not even sure which side of the toothbrush you're holding. The Sonicare has a two minute timer that will help you out. The quadpacer even beeps in 30 second intervals to let you know when it's time to move on to a different part of the mouth. Get the brushing that's recommended by dental professionals and get a consistent clean every time.
The toothbrush also claims to remove 7x more plaque than manual toothbrushes. You'll notice whiter teeth in one week and improve your gum health in two weeks. Plus this deal comes with a charging glass and a travel case so you can use the Sonicare on the go if you're traveling for business or vacation or something like that.
