Charge your phone or your car with Tacklife's jump starter for less than $40
If you don't have a portable jump starter in your car, you should. It's definitely one of those "better to have it and not need it..." sort of devices. At the very least, you can use it to charge your mobile devices in a pinch, but it might just save you from needing to call your roadside emergency hotline at some point. The Tacklife T6 16500mAh 600A Peak Quick Charge 3.0 portable car jump starter is down to $38.98 on Amazon. To get that price, clip the 9% off on-page coupon and use code KE7PM467. The discounts stack to bring the total all the way down from the $70 it is selling at. The jump starter more regularly sells for around $65, and we have never seen it go this low before. The last time it went on sale, it only dropped to around $45.
Tacklife T8 Max 1000A Peak 20000mAh jump starter
$49.99 $100.00 Save $50
Use the code with the on-page coupon. Works with all gas engines and 6.5L diesel engines. Can jump start up to 40 times on a single charge. Has 3 quick charge USB ports and a 12V 10A DC port. Includes built-in LED flashlight and two-year warranty.
Tacklife Electric Arc Lighter
$8.49 $16.99 Save $8
The 220mAh battery works up to 400 times and recharges via USB. No more gas or fuel. No mess, no smell. The flexible neck is good for lighting candles, camp stoves, and more. Plus, it's windproof for outside use. Use the below code for 50% off.
Tacklife T8 800A Peak 18000mAh car jump starter with LCD display and quick charger
$55.99 $80.00 Save $24
Works on most cars, SUVs, trucks, and more. Can jump start up to 30 times on a single charge. Charge mobile devices with two USB ports and an 18000mAh capacity. Even has Quick Charge and a built-in LED flashlight. Covered by a two-year warranty.
Tacklife Power Station 300W
$216.97 $309.97 Save $93
Getting off the grid for a while is easier with Tacklife's new Autumn Exclusive Power Station. This 300w portable solar generator drops nearly $100 in price when you use the following promo code during checkout.
Tacklife 1200A Car Jump Starter (KP120)
$43.98 $79.97 Save $36
Packing for your summer road trip won't be complete without ensuring you can jump-start your vehicle's battery in a pinch. This 1200A peak model is suitable for up to 8L gas or 6L diesel engines. Use the 5% on-page coupon and the below code to save.
Tacklife's portable jump starter is small enough to fit in your car's glove compartment, but it has enough juice to start cars, trucks, motorcycles, and other vehicles up to 30 times on a full charge. The included jump cables have eight built-in protections, including being spark-proof, and protection from reverse polarity, over-current, high temperatures, overloads, and more. The flashing light uses an audio-visual system of beeps and flashes to let you know when something isn't working or going according to plan.
The two USB outputs have Quick Charge 3.0 so you can recharge compatible mobile devices super fast. Of course, even if your devices don't have Quick Charge, you can still power up. Charge just about anything, including smartphones, tablets, and Kindles. The 12V 10A output can power air pumps, vacuums, and other accessories through the included cigarette lighter adapter. There is also an LED flashlight with three available modes.
It comes with a two-year warranty, and users give it 4.5 stars based on 708 reviews.
