Charge your phone for less with up to 40% off these Belkin wall chargers
Black Friday is a great time to get your hands on new charging gear for your Android device.
Right now on Amazon, you can get up to 40% off these Belkin USB-C wall chargers that deliver fast charging PD through GaN, or you can spend just $12 on a compact charger that delivers PD Fast charging to any device that will take it.
Because they work with USB-C, they can be used with basically any Android phone as well as iPhone and iPad, and boast a much smaller size than other chargers that deliver similar wattage.
Lowest-ever price
Belkin's USB-C GaN wall charger delivers fast charging PD in a low profile form factor. It can charge a Google Pixel to 50% in just 37 minutes, at a size that is roughly 20% smaller than most chargers of a similar power grade without generating too much extra heat.
The compact USB-C wall charger is even cheaper, so is a perfect travel companion thanks to its tiny size. It's also durable and great for hard-to-reach outlets. You can save even more if you buy them in a two-pack that costs just over $22. Thanks to USB-C this works with pretty much any Android phone and iPhones too with the right cable, as well as iPads and other USB-C tablets. Get stuck into these deals now!
Be an expert in 5 minutes
