Charge your gear quickly with Anker's PowerPort Atom III USB-C GaN charger at 35% off
More and more of our devices are starting to adopt USB-C, from our phones to our laptops, so it makes total sense to consolidate our charging gear so we don't have to carry multiple bricks and cables around each day. Anker's 60W PowerPort Atom III USB-C wall charger can be used to juice up all manner of devices and, right now, it's $15 off. The drop to $28.15 from its usual $43 price point marks a return to its lowest ever price.
Anker Soundcore Life Q30 hybrid active noise-cancelling Bluetooth headphones
$59.99 $79.99 Save $20
These hybrid Bluetooth headphones reduce ambient noise up to 95% thanks to active noise-cancelling mics. The battery lasts up to 40 hours with ANC on or 60 hours with it off, and recharge via USB-C. Clip the $20 on-page coupon.
Anker Powerline II 6-feet USB-C to Lightning cable
$12.74 $15.00 Save $2
When using a USB-C power adapter (not included), you'll get the fastest possible charge for your iPhone. Plus you can seamlessly sync and charge your Mac. This is Apple MFi certified and lasts 12 times longer than other cables.
Anker Liberty Air 2 Pro true wireless earbuds Best Buy
$79.99 $130.00 Save $50
These earbuds have active noise-cancelling that's customizable with a simple app. You'll get a total of 26 hours of playtime with seven hours from a single charge and the rest from the charging case. Uses USB-C and has wireless charging.
Anker Soundcore Rave Neo portable Bluetooth speaker with LED lights
$84.99 $120.00 Save $35
Includes a rechargeable battery that will last for up to 18 hours and can charge other devices with the USB port. IPX7 rated for water resistance. The built-in LED lights will sync to the music you're playing. Connect multiple speakers together.
Anker Soundcore Liberty 2 Pro true wireless earbuds black
$49.99 $100.00 Save $50
They last for up to eight hours on a single charge with up to 32 hours total using the charging case. They have quick charge so you can get two hours after 10 minutes spent charging. They also charge via USB-C or a Qi wireless charger.
Though this well-reviewed wall charger is equipped with just one USB-C port, it has a 45W output so it can be used with a variety of device types including larger tech gear like laptops. In addition to its USB-C connector, there's also a USB-A port with a 15W output for powering up a second device simultaneously.
Even though it packs the same sort of power as a MacBook charger, it has a 15% smaller form factor making it perfect for travelling with. It also has a folding plug. Unlike previous wall chargers, this one is powered by gallium nitride which generates less heat and allows Anker to make it much more compact.
With so many devices going all-in on USB-C, you can future-proof yourself with this high-performance wall plug and reduce travel clutter at the same time thanks to its USB-A port. If one USB-C port is not enough for you, you can also snag a 2-port version, though that model is only $5 off right now. It's worth noting that neither option includes a USB-C cable so you'll need to use your own or add one to your order.
Adam Oram is a Senior Writer at iMore. He studied Media at Newcastle University and has been writing about technology since 2013. He previously worked as an Apple Genius and as a Deals Editor at Thrifter. His spare time is spent watching football (both kinds), playing Pokémon games, and eating vegan food. Follow him on Twitter at [@adamoram](https://twitter.com/adamoram).
