Charge two USB-C devices at once with Anker's car charger on sale for $20
Starting to convert a lot of your devices to USB-C and need the chargers to match? Grab the Anker PowerDrive+ III Duo 2-port car charger on sale for $19.99 at Amazon. This USB-C charger normally sells for $28 and is temporarily down to its lowest direct price drop ever.
Anker Soundcore Life Q30 hybrid active noise-cancelling Bluetooth headphones
$59.99 $79.99 Save $20
These hybrid Bluetooth headphones reduce ambient noise up to 95% thanks to active noise-cancelling mics. The battery lasts up to 40 hours with ANC on or 60 hours with it off, and recharge via USB-C. Clip the $20 on-page coupon.
Anker Powerline II 6-feet USB-C to Lightning cable
$12.74 $15.00 Save $2
When using a USB-C power adapter (not included), you'll get the fastest possible charge for your iPhone. Plus you can seamlessly sync and charge your Mac. This is Apple MFi certified and lasts 12 times longer than other cables.
Anker Liberty Air 2 Pro true wireless earbuds Best Buy
$79.99 $130.00 Save $50
These earbuds have active noise-cancelling that's customizable with a simple app. You'll get a total of 26 hours of playtime with seven hours from a single charge and the rest from the charging case. Uses USB-C and has wireless charging.
Anker Soundcore Rave Neo portable Bluetooth speaker with LED lights
$84.99 $120.00 Save $35
Includes a rechargeable battery that will last for up to 18 hours and can charge other devices with the USB port. IPX7 rated for water resistance. The built-in LED lights will sync to the music you're playing. Connect multiple speakers together.
Anker Soundcore Liberty 2 Pro true wireless earbuds black
$49.99 $100.00 Save $50
They last for up to eight hours on a single charge with up to 32 hours total using the charging case. They have quick charge so you can get two hours after 10 minutes spent charging. They also charge via USB-C or a Qi wireless charger.
Anker's car charger includes two USB-C ports with up to 48W of power. One port has 30W and the other 18W, which makes one better for larger appliances like laptops and the other better for smartphones and tablets. And, of course, you can charge multiple devices at once with high speeds for all your devices.
The ports also use Anker's PowerIQ 3.0 technology. This feature helps the device know what is being plugged in, how much charge it can take, and helps provide it the fastest possible speeds. This way the ports will work with basically any USB-C device that's plugged into them.
Like other Anker devices, the car charger also has a MultiProtect safety system. Completely protect your gear from over-heating, short circuits, over-charging, and more.
This comes with an 18-month warranty from Anker. There are only 10 user reviews so far, but those write ups give it 4.9 stars out of 5.
