Charge three devices at once with RAVPower's 22000mAh Power Bank on sale for $16
Making sure you have a way to power up all your devices while you're traveling is important, which is why you should give some serious consideration to this RAVPower 22000mAh Portable Power Bank. It's equipped with three USB ports and drops to just $15.99 at Amazon today when you use promo code RB6UXPIH during checkout. That saves you $10 off its usual cost of $26, though this offer is only valid on the black version of this power bank.
RAVPower 65W 4-port USB Desktop Charging Station
$34.99 $49.99 Save $15
Keep USB ports close by with this 65W USB Desktop Charging Station by RAVPower. It's equipped with two USB-C ports as well as two USB-A ports. Clip the coupon on its product page and use the following code at checkout to save $15.
RAVPower 10000mAh portable charger dual USB power bank
$9.99 $15.00 Save $5
The ultra slim power bank is only 15mm deep, so it's extremely portable. The battery size of 10000mAh is enough for a full charge of even the largest phones. Can charge two devices at once and has built-in safety features to protect them all.
RAVPower 61W Power Delivery 3.0 USB-C 2-port wall charger
$23.39 $30.00 Save $7
Has 61W output with Power Delivery 3.0. Can charge a MacBook in 2.1 hours. Can detect what's plugged in and deliver fastest possible speeds. Wants to be portable with slim, compact design and foldable pins. Includes built-in safeguards.
RAVPower 48W USB-C Car Charger with Power Delivery 3.0 and Quick Charge 3.0
$14.99 $19.99 Save $5
RAVPower's fast dual-port car charger features a 30W Power Delivery 3.0 USB-C port along with an 18W Quick Charge 3.0 USB-A port. Clip its on-page coupon to snag this deal.
RAVPower 25000mAh solar phone charger outdoor portable charger
$21.99 $46.00 Save $24
Use sunlight to recharge this charger's batteries or plug it in via micro USB or USB-C. The 25000mAh capacity is enough to keep all your devices going outdoors. Includes an LED flashlight and SOS mode for emergencies. Waterproof and dust proof.
RAVPower's 22000mAh features iSmart technology so that its USB ports automatically provide the optimal output per device up to 5.8A. With its large capacity, you'll be able to charge devices like the iPhone X nearly five times before the power bank would need to be powered up again. Its high-density li-polymer battery is capable of retaining up to 80% of its full capacity even after 500 charge-discharge cycles to ensure it's able to be used for years to come.
Integrated LED lights show when the power bank is on and ready to charge your devices. RAVPower includes two micro USB charging cables with this power bank to help you keep it powered up, as well as a carrying case to store it all in while traveling.
Nearly 200 customers have left reviews for this portable power bank at Amazon, resulting in a rating of 4.6 out of 5 stars. Shipping at Amazon is free on orders totaling $25 or more, or with an Amazon Prime membership. If you've never been a member before, you can start a free 30-day trial to score free two-day shipping with no order minimum, along with access to the Prime Video streaming service, exclusive members-only discounts, and more.
For even more options for portable power, be sure to check out this guide to the best power banks under $30.
Be an expert in 5 minutes
