Charge six devices at once with Anker's tiny USB power strip now down to $17 at Amazon
Trying to find a way to charge multiple devices around your desk becomes a lot easier with a power strip like the Anker PowerPort Cube. It's equipped with three USB ports and three AC outlets so you can power up to six devices all at once, and today it's down to just $16.99 at Amazon when you clip the coupon on its product page. That saves you $9 off its full cost and brings it down to the best price we've ever seen it reach. Today's offer is only available on the white version of this power strip, though the black model is on sale for a few dollars more at $19.99.
Anker Soundcore Life Q30 hybrid active noise-cancelling Bluetooth headphones
$59.99 $79.99 Save $20
These hybrid Bluetooth headphones reduce ambient noise up to 95% thanks to active noise-cancelling mics. The battery lasts up to 40 hours with ANC on or 60 hours with it off, and recharge via USB-C. Clip the $20 on-page coupon.
Anker Powerline II 6-feet USB-C to Lightning cable
$12.74 $15.00 Save $2
When using a USB-C power adapter (not included), you'll get the fastest possible charge for your iPhone. Plus you can seamlessly sync and charge your Mac. This is Apple MFi certified and lasts 12 times longer than other cables.
Anker Liberty Air 2 Pro true wireless earbuds Best Buy
$79.99 $130.00 Save $50
These earbuds have active noise-cancelling that's customizable with a simple app. You'll get a total of 26 hours of playtime with seven hours from a single charge and the rest from the charging case. Uses USB-C and has wireless charging.
Anker Soundcore Rave Neo portable Bluetooth speaker with LED lights
$84.99 $120.00 Save $35
Includes a rechargeable battery that will last for up to 18 hours and can charge other devices with the USB port. IPX7 rated for water resistance. The built-in LED lights will sync to the music you're playing. Connect multiple speakers together.
Anker Soundcore Liberty 2 Pro true wireless earbuds black
$49.99 $100.00 Save $50
They last for up to eight hours on a single charge with up to 32 hours total using the charging case. They have quick charge so you can get two hours after 10 minutes spent charging. They also charge via USB-C or a Qi wireless charger.
This is about as small a power strip you can expect to find, especially considering it manages to fit six ways to charge in a compact fashion. The USB ports have a max output of 18W and the outlets have a max of 1250W, which is plenty of power for whatever you're plugging. At less than 2.5 cubic inches, it won't take up any space wherever you choose to put it, and you can easily bring it with you in your laptop bag. Anker's PowerPort Cube even has an adhesive backing on the bottom which lets you stick it to the underside of a desk or another flat surface.
Anker backs up your purchase with an 18-month warranty. At Amazon, more than 1,300 customers left a review for this power strip resulting in a strong rating of 4.6 out of 5 stars.
Shipping at Amazon is free on orders totaling $25 or more, or with an Amazon Prime account. If you've never been a Prime member before, you can start a free 30-day trial to gain access to all of its perks including free two-day shipping with no order minimum, access to the Prime Video streaming service, exclusive members-only deals, and more.
