Charge safely in over 200 countries with more than 30% off this universal travel adapter
One thing you don't want to forget when flying overseas is a Universal Power Adapter. This essential travel accessory enables you to charge devices in countries with varying AC outlets, and while you could probably pick one up during your trip for a small fortune, you'd save big by staying prepared and buying one beforehand. Consider this Xcentz Universal Travel Power Adapter for instance. It's normally affordably priced at just $13 on Amazon, and by entering promo code XCENTZS98 during checkout, you can snag one for only $8.99 right now. That's one of its lowest prices in history, but even at regular price this adapter is well worth its cost.
The Xcentz travel adapter works in over 200 countries and features USA, EU, UK, and AU plugs that you can slide out as necessary when it's time to plug something in. It's smaller than a credit card, and lightweight as well, offering little downside to bringing it along on all your travels. The adapter is equipped with two USB ports and a travel plug which allow you to charge up to three devices all at once at 2.4A. There's even a built-in safety smart chip which helps ensure stable, fast charging.
It's important to be aware that this adapter converts the power outlet only; it doesn't convert electrical output current or voltage, and it can't support high power appliances over 1840W like some hair dryers or irons either. With that in mind, a universal travel adapter voltage converter might be a better fit for your trip.
Shipping at Amazon is free on orders totaling $25 or more, or with an Amazon Prime membership. If you're not a member already, consider starting a free 30-day trial to score free two-day shipping with no order minimum, exclusive members-only discounts, and more.
