Charge quickly with Poweradd's 18W USB-C power bank down to just $8
You are now subscribed
Your newsletter sign-up was successful
There's nothing worse than your phone running out of juice before the end of the day, so it's always worth having a power bank in your bag or jacket pocket. This Poweradd portable charger with USB-C is perfect for taking on the go thanks to its slim design and right now you can snag it for its best price yet when you clip the coupon on its product page and then enter promo code MBXPL4P8 during checkout. That drops it down to $8.29 which is lower than we've seen it go before.
$99.99 $102.19 Save $2
$14.99 $29.99 Save $15
Upgrade the way you power up with this USB-C power strip featuring five AC outlets, two USB-A ports, and a USB-C port for eight ways to charge your devices, as well as surge protection.
$33.99 $50.99 Save $17
$89.99 $102.19 Save $12
$33.54 $48.99 Save $15
With a 10000mAh capacity, it is capable for charging most smartphones two to three times over which is more than enough to get you through even the heaviest day of usage. It has a regular USB-A port as well as a USB-C port with Power Delivery up to 18W for fast charging compatible phones. Regardless of which phone you're rocking, you'll be able to get powered up and perhaps even give a friend some juice at the same time. The USB-C does double duty as an input, too, meaning you'll be able to get the power bank back up to 100% much quicker than other options that recharge via Micro-USB, though you'll probably want to add a fast USB-C wall charger to your order to help with that if you don't already have one. There's an LED indicator on the front letting you know when it's time to recharge.
One neat added extra with this purchase is a 3-in-1 charging cable that can power up your devices via Micro-USB, USB-C, or Lightning meaning you don't have to pack a bunch of cables when you travel. You also get a 2-year warranty and a carrying pouch. Existing owners rate this power bank highly with an average score of 4.8 stars out of 5 based on over 460 reviews.
