Charge laptops, phones, and more with Anker's discounted PowerCore+ bundle at nearly 45% off
Staying connected and powered up while on the go gets easier with Anker's PowerCore+ 26800mAh PD Portable Charger bundle, and now it's more affordable too. Amazon has this 3-piece bundle on sale for just $67.99 while supplies last. That brings the set down to its lowest price ever for a total savings of $53 off; it sells for as much as $130 regularly.
This 3-piece travel charging bundle comes with Anker's PowerCore+ 26800mAh portable power bank, a 30W USB-C Wall Charger featuring Power Delivery, and a USB-C to USB-C cable. Separately, just the power bank alone regularly sells for $70 at Amazon, while the USB-C Wall Charger is normally priced close to $30.
Anker Soundcore Life Q30 hybrid active noise-cancelling Bluetooth headphones
$59.99 $79.99 Save $20
These hybrid Bluetooth headphones reduce ambient noise up to 95% thanks to active noise-cancelling mics. The battery lasts up to 40 hours with ANC on or 60 hours with it off, and recharge via USB-C. Clip the $20 on-page coupon.
Anker Powerline II 6-feet USB-C to Lightning cable
$12.74 $15.00 Save $2
When using a USB-C power adapter (not included), you'll get the fastest possible charge for your iPhone. Plus you can seamlessly sync and charge your Mac. This is Apple MFi certified and lasts 12 times longer than other cables.
Anker Liberty Air 2 Pro true wireless earbuds Best Buy
$79.99 $130.00 Save $50
These earbuds have active noise-cancelling that's customizable with a simple app. You'll get a total of 26 hours of playtime with seven hours from a single charge and the rest from the charging case. Uses USB-C and has wireless charging.
Anker Soundcore Rave Neo portable Bluetooth speaker with LED lights
$84.99 $120.00 Save $35
Includes a rechargeable battery that will last for up to 18 hours and can charge other devices with the USB port. IPX7 rated for water resistance. The built-in LED lights will sync to the music you're playing. Connect multiple speakers together.
Anker Soundcore Liberty 2 Pro true wireless earbuds black
$49.99 $100.00 Save $50
They last for up to eight hours on a single charge with up to 32 hours total using the charging case. They have quick charge so you can get two hours after 10 minutes spent charging. They also charge via USB-C or a Qi wireless charger.
The PowerCore+ 26800 is one of Anker's most powerful charging devices. It supports Power Delivery and has enough output that it's compatible with the Nintendo Switch, the Apple MacBook, and tons of other USB devices. The ports include one USB-C port (with Power Delivery) and two regular USB-A ports. The 26800mAh battery can charge one phone half a dozen times or you can plug in three items at once and have enough power to charge them all.
With the included 30W USB-C wall charger, you can power up the power bank within just a few hours. This charger can be used directly with your Switch or MacBook or other USB-C powered devices as well. It also comes with a micro-USB cable, a USB-C to USB-C cable, a travel pouch, and Anker's 18-month warranty.
More than 900 customers left a review for this 3-piece bundle at Amazon, resulting in a rating of 4.3 out of 5 stars.
