Charge four devices at once with EasyAcc's portable battery charger on sale for $19
Heading out on the town with a few mobile devices tagging along for the ride? Need a way to make sure all of them stay charged up even when you can't stop to plug into an outlet? The EasyAcc 20000mAh Fast Recharge portable charger is the answer. It's down to $18.99 with code MVQD4QWJ. That's one of the best deals we've ever seen and better than any direct price drop on the power bank. It has been selling for around $38 since last year, and when it does drop in price directly doesn't go much lower than $30.
EasyAcc Gooseneck Tablet Holder
$12.99 $25.99 Save $13
Available in white, this stand is made of magnalium alloy for a durable yet flexible arm that can twist into various viewing positions. It's suitable for devices from 4-10.6 inches wide and is half off with the below code.
EasyAcc Battery Charger Case Works for iPhone X XS, Wireless Charge Case Cover 5000mAh Battery Qi Rechargeable Shell
$16.99 $19.99 Save $3
$17.99 $19.99 Save $2
$18.99 $19.99 Save $1
$19.99 $18.99 Save $-1
The EasyAcc charger is the perfect companion when you have multiple smartphones and maybe a tablet or laptop with you and need to use them all. Not only does it have a super huge capacity of 20000mAh, which is good enough for several recharges of even a larger smartphone, but it also has four outputs. The quadruple USB-A ports can charge all your devices simultaneously, and they have the technology to detect what's plugged in to deliver the fastest possible charge. You'll be able to stay topped off while running to your next class or leading a meeting at work.
You can also use the dual input ports to add power twice as fast. With such a high capacity, the EasyAcc would normally take quite a long time to refill. With both ports charging as fast as they can, you'll be ready to go in less than six hours. Grab a two-port USB wall charger so you can recharge your power bank wherever you go.
The built-in safeguards are there to protect your new battery charger and your devices plugged into it. You won't have to worry about things like overcharging, overheating or short circuiting. Plus, it conforms to known standards from agencies like the FCC for this sort of thing.
EasyAcc backs it up with an 18-month warranty.
