If you're in the market for some upgraded home security, you're in luck. Right now Amazon is discounting a ton of Ring gear including its Ring Spotlight and Ring Floodlight home security cameras. The best part? It's also throwing in an Echo Dot at no additional cost. With up to $50 off plus an Echo Dot worth $50, you stand to save as much as $100 with these sales. We don't know exactly when prices will rise again, so you want to place your orders as soon as possible in order to not miss out.
The Spotlight Cam — which is available wired or battery-powered with the same $30 discount — allows you to watch HD video of your home, communicate with people using the built-in two-way audio, and see at night with the bright LED spotlights. You can get on-demand live video, and there's a 110-decibel alarm if you need it. If the camera gets stolen from its outside placement, Ring will replace it for free. At $169 it is down to one of its best prices ever for the camera alone, and the Echo Dot is just the icing on the cake.
The motion-activated Ring Floodlight Cam is an HD security camera with built-in 1,800 Lumens floodlights, a siren, and two-way talk. Right now it is $50 off in black or white and the free Echo Dot scores you a further $50 in savings. It has an ultra-wide viewing angle and it's easy to view real-time surveillance footage from anywhere in the world using the Ring app. You can see, hear, and speak to visitors from the Ring app as well. The 1080p even works at night thanks to its infrared vision. Lifetime theft protection is also included with your purchase.
With either camera, you can use your free Echo Dot to communicate with whoever is outside and you use your Echo device with a screen to view a live video feed too.
Amazon is also discounting its Ring Video Doorbells and Ring Alarm systems right now, so you can protect your whole home for less. Check out our list of the best smart home security tech for more ways to guard your property.
Be an expert in 5 minutes
