Build your Philips Hue smart light setup with up to 20% off
While we're all stuck inside over the next few weeks, why not make a few improvements and enhancements to your home? Philips Hue is having a mix-and-match sale on smart bulbs that could save you up to 20% off your purchase. You'll just need to add four or more eligible items to your cart to take advantage of today's discount, and the more you buy, the more you'll save.
Today's sale is a great time to buy even if you're new to Philips Hue products. The essential Hue Bridge is included in the sale to get newcomers started, so don't forget to add that item to your cart if you don't own one already.
You'll save 10% on your purchase by adding four of the eligible items in the sale to your cart. Meanwhile, five items will save you 15%, and six items or more will save you 20% on your order. There's a nice mix of Philips Hue smart bulbs included in the sale too, so you have a few different options to choose from.
Philips Hue bulbs are not just extremely useful but pretty fun as well. You'll be able to control whichever bulbs you buy using the Philips Hue app on your smartphone or tablet. Some of them can change colors too. Using the app, you'll be able to schedule when you want the bulbs to power on automatically or turn them on manually at any given moment. They're also compatible with Amazon Alexa and Google Assistant, so if you happen to have a device like the Echo Dot at home, you could begin voice controlling the bulbs as well.
For even more smart ways to improve your home over the next few weeks, check out this guide to the best smart home products under $100.
Be an expert in 5 minutes
