The Bose SoundLink Revolve+ 360-degree Bluetooth speaker has dropped to $239 today
The Bose SoundLink Revolve+ portable Bluetooth speaker is down to $239 at Amazon. You can get this price in both Triple Black and Lux Gray. The speaker normally sells for $299. Today's drop matches a low we've only seen for major events like Black Friday. This is a price drop from Bose, so it's not exclusive Amazon. Find this price at B&H and Best Buy among others.
When you buy a Bose product at least you know you're getting some good Bose sound. The Revolve+ has a full range driver and delivers audio in a full 360 degrees. That's nice because the speaker is meant to be portable, so at least you don't have to worry about placement when you finally put it down. Just drop it and enjoy some tunes. The audio is deep, loud, and powerful.
Speaking of portability, the Revolve+ also uses a flexible fabric handle that's easy to grab. The aluminum body is very durable, and it's also water resistant with an IPX4 rating. That means you don't have to worry about a sudden downpour if you're using it for a backyard barbecue or any splashing if it's sitting next to you at the pool. Probably don't want to go scuba diving with it, though.
The rechargeable battery lasts for up to 16 hours on a single charge. The Bluetooth pairs easily via voice prompt. With the built-in mic, you can use the speaker to take calls or access a voice assistant like Siri or Google Assistant. The wireless range works up to 30 feet away, so you don't have to get off the couch to skip a track.
Buy more than one and pair them together to create stereo sound. Bose SimpleSync makes that a really simple process and helps keep your audio in sync between the two devices. Use the Bose Connect app to switch between connected Bluetooth devices.
