The Bose SoundLink II Bluetooth headphones have matched a low price of $159
Bose Soundlink
Bose Soundlink (Image credit: Amazon)
The Bose SoundLink II around-ear Bluetooth headphones are down to $159 on Amazon. These are one of Bose's most consistent headphones and have been around for a while now. They are normally $229 and have sold pretty regularly at that price. Today's deal matches the lowest we have ever seen on the SoundLink II, and it's a price drop that has only occured a few times before.
These are very light over and around ear headphones that are designed to immerse you in your music without weighing you down. They have a deep sound and an improved equalizer that provides best-in-class performance for headphones like this.
You can switch between a Bluetooth wireless connection or a wired one, and it actually can switch between two Bluetooth devices simultaneously. That way you won't lose connection to your smartphone when you want to switch over to watch a video on your tablet. Plus, they use Bluetooth 4.0 technology, which means a much stronger connection than previous generations and a better rate of power consumption so you won't drain your battery as fast.
The headphones also have an advanced microphone system that helps keep your voice crystal clear in noisy environments. Go hands-free and take calls even while you're moving around your house listening to the latest Taylor Swift album. Use the built-in controls on the earcup to easily switch between calls, change music tracks, and control other functions.
You'll get up to 15 hours of playtime on the rechargeable battery, but of course you can always go wired if you need to when the battery runs low and you don't have the time to charge it. They even come with a backup audio cable for when you need to do that. The headphones also come with a USB charging cable and a carrying case so you can take them on the road.
