Keep your grass green and use less water with the discounted Blossom Smart Sprinkler Controller
Lawn care definitely requires a lot of work, but there are some parts of it that you can automate, and probably should. Watering the grass doesn't have to be a cumbersome task anymore thanks to the Blossom 7 smart watering controller, and today you can score one for just $39. Back in June this unit was selling for as much as $130.46, and while it has sold for a little cheaper in the past, this is the best deal we've seen for it in recent months.
The Blossom 7 uses real-time satellite based weather data so that your sprinklers only run when they need to. Setting it up is as simple as taking out your existing unit, and connecting the zone wires to the corresponding locations on this. It can be set up in as little as 15 minutes, and controlled right from your smartphone once it's all done. It's capable of handling seven different zones of sprinklers, so it's enough for large systems and smaller ones at the same time.
From the app, you can create a watering schedule, optimize different zones based on what type of ground cover and plants are in it, and so much more. Compared to some of the competition, like the Orbit units or Rachio, this one is far more affordable and you don't have to sacrifice features for the lower cost. If you have a sprinkler system at home and are tired of wasting money on water that you don't need to actually use, grab one of these today before the price jumps back up!
