Best workout earbuds and headphones for Android users
These can handle your extreme side.
At a glance
1. Best overall
2. Best value
3. Best battery life
4. Best value over-ear
5. Best on-ear headphones
6. Best sporty style
7. Best on a budget
8. Best open-ear
How to choose
How we test
Headphones should be an important part of your workout gear and routine. This is the best time to set yourself a healthy resolution for the new year, and what's a better motivator than buying the best workout earbuds and headphones for the job.
Not every set of headphones is suitable, though. Everyone works out differently so the right pair of headphones needs to be able to handle the sweat, the weather, the impact, and everything else that comes along with your routine. Whether you work out inside or do it in the great outdoors, the right pair is available to make everything a little bit better.
We test a lot of wireless headphones and earbuds to help us narrow down the best models and materials for a good workout.
At a glance
Best overall
The long-awaited refresh of the Powerbeats line, the Powerbeats Pro, is IPX4 resistant, has great battery life, and has a built-in heart rate monitor. Apple's H2 chip keeps it all running smoothly, too.
Best value
If you're looking for something a bit simpler (and cheaper) the Treblab X3 Pro could be the answer. They lack ANC, but are water resistant with a long battery life which makes them great for runs or hikes.
Best battery life
With up to 12 hours per charge, these earbuds will easily last all day. They're IP68 rated for dust and water resistance, and support ANC to block out annoying sounds at the gym.
Best value over-ear
Over-ear headphones can give you better sound quality and long-term comfort than earbuds. The Space One headphones from Anker deliver excellent sound and battery life at an affordable price, with solid app support.
Best on-ear
The JBL Tune 670NC offer solid noise cancelation for on-ear headphones, which is key given how uncommon it is for these types of headphones. Comfortable and lightweight, they feel good during every workout.
Best sporty style
The Powerbeats Pro earbuds sound great, fit well, and stay in place with hooks over your ears. If you've got an iPhone, the H1 chip inside makes pairing a breeze, yet they still work great on Andoird.
Load the next 2 products ↓
Best on a budget
The Back Bay Tempo 30 earbuds are a sleek set of budget earbuds with good sound quality, a long battery life, and even IPX7 water resistance. You can also get these earbuds in just about any color.
Best open-ear
Whether you're running or cycling on a busy path, it's sometimes essential to be able to hear what's going on around you. The Shokz OpenRun Pro 2 headphones don't block your ears so you're free to hear what's around you.
Best overall
Reasons to buy
Reasons to avoid
Six years after the 2019 release of the original Powerbeats Pro means the company has had plenty of time to improve the product. They have done just that, and the Powerbeats Pro 2 are the best overall workout headphones you can buy.
The new design is welcome, even if it's still not the perfect fit for everyone. It's a lot closer than other ear-hook headphones. New drivers and Apple's H2 chip deliver decent audio quality with little to no Bluetooth weirdness and power an accurate heart rate monitor; something important when working out.
They also sport something new for the Powerbeats line: ANC. Active Noise Cancellation can snuff out pesky noises when you're working out indoors and following a routine from your favorite workout app, but being able to shut it down if you're cycling or running the roads is important too. It's there when you need it.
If you want the security of an ear-hook design and the comfort of silicon tips paired with an outstanding and tough workout buddy, these are the ones to buy.
Best value
2. Treblab X3 Pro
Our expert review:
Reasons to buy
Reasons to avoid
Sometimes, you don't have to spend a lot to get a lot, and that's essentially what you get with the Treblab X3 Pro. Their ear hook design is great for stability, especially when you're being active and don't want the earbuds to fall out at the wrong time. With stability, you often get better comfort, and the two do go together well here.
The IPX7 rating is great for both water and sweat resistance, and the rubberized veneer makes them easier to manage and clean. Wipe them down after a workout, and you should have these playing for some time to come. If you're just looking for earbuds that stay firmly in place while you work out or go for a run, these will do just fine.
You do get Beats-style audio quality, so if you're into heavier bass, you'll feel at home moving to tunes coming through. There are no actual special audio treatments beyond that, including the lack of an app to customize anything, so what you hear is going to be what you get. The bass is nice, thick, and well suited to listening while active. There is no ANC or ambient mode, so you can't block out or let in the outside world when you see fit.
Battery life can last up to 9 hours per charge depending on volume level. The case, which is going to be larger than most, has another four charges inside, for up to 45 hours total. If you're only using these for workouts, you can go for weeks before needing to fully recharge. No fast charging here, but it takes just two hours to fill them up again.
Best battery life
Reasons to buy
Reasons to avoid
Anker found some moderate success with the previous Soundcore Sport X10, so a sequel in the Sport X20 bodes well for maintaining what went well the first time. Ear hooks aren't for everyone, but it's hard to argue with their ability to maintain a good seal since the weight and pressure are largely allocated to the hooks rather than the buds. Anker makes them flexible enough to feel like they wrap around your ear comfortably. More importantly, they're also stable as you move.
Five sets of silicone ear tips in the box, including extra-small and extra-large sizes, accommodate those with smaller or larger ears. That increases the chances you'll find a pair that gives you the tightest seal to keep the best sound from leaking out.
The IP68 rating gives them excellent dust and water resistance. You shouldn't have any issues with runs or workouts, provided you keep them clean after you sweat all over them. Take care of them and they're likely to last even longer. Physical buttons make controls easier to manage, especially when using them during whatever exercise you engage in.
Music will sound great for what these earbuds cost, and you can always adjust the sound signature through the Soundcore app. You have plenty of presets to choose from or tune your own sound with the EQ. ANC is solid when you want to drown out the background, while transparency is fine at filtering in those sounds to know your surroundings.
Without ANC, Anker claims the earbuds can play for up to 12 hours per charge, or 10 hours with it on. Those numbers are based on default volume. Raise it and battery life falls. The case, which isn't the highest quality, doesn't have wireless charging but does have another three full charges for the earbuds.
Best value over-ear
4. Anker Soundcore Space One
Our expert review:
Reasons to buy
Reasons to avoid
Over-ear headphones may not be everyone's cup of tea for a workout, but if they're your preference, then you may like the Soundcore Space One for their value and performance. There's no specific durability rating, but you can get away with using them while working out or being active.
What helps these achieve that is the larger earcups that do a nice job of staying in place. While not ideal for runs (maybe on a treadmill), they should stay put in the gym.
Onboard ANC is solid for headphones in this price range, thanks in part to passive isolation courtesy of the ear cups, so staying focused by drowning out background noise is just a button away.
It doesn't hurt that they sound good, too. The soundstage is vibrant, and if you find it needing something more, use the excellent Soundcore app. Its equalizer lets you tweak the sound however you want, plus over 20 presets to use on top of that. Even the ANC has three settings within the app, giving you a good level of control over what these headphones can do. With LDAC codec support, you can also enjoy lossless playback on any devices or content that can play it.
You also won't be charging them all that often. These headphones last up to 55 hours per charge with ANC off or up to 40 hours when it's on. So in the odd time you might find them dead and need a quick boost to listen to music for a workout, plug them in via USB-C for five minutes to get up to four hours of playback.
5. JBL Tune 670NC
Our expert review:
Reasons to buy
Reasons to avoid
On-ear headphones aren't for everyone but they can still sound great without giving you total isolation from the environment around you. The JBL Tune 670NC are one of the best you'll find in this unique category, mainly because they deliver slightly improved audio, despite the on-ear design making it tougher to keep some of the bass from leaking out.
There is ANC here, so you can block out background noise when you want to stay focused on what you're doing. While not all that exceptional, it does the job. Unlike previous versions, the Tune 670NC gain access to all the features and settings available in the JBL Headphones app, including the EQ to tweak the sound how you want and accessing noise-canceling and transparency modes, among other things.
JBL does its best to make the headphones comfortable to wear, though on-ear designs aren't likely to feel as nice as over-ears for longer periods. That makes the Tune 670NC nice for workouts where you may be done after an hour or so. After you're done, you can wear them on your commute home or even wear them at work.
You won't be charging them all that often. They can go for up to 44 hours per charge with ANC on (70 hours when off), and if you need a quick boost from a low battery, plug them in for five minutes and get up to three hours of playback.
Best sporty style
6. Beats Powerbeats Pro
Our expert review:
Reasons to buy
Reasons to avoid
If you're an Apple user looking for something sporty, don't start with the AirPods; start with the Powerbeats Pro. It's not just because Apple owns all things Beats but because these earbuds are much better designed for activity.
The ear hook design gives them an edge in practicality for running so you don't have to worry about them falling off. Also, despite a more modest IPX4 rating, the more rubberized finish offers greater sweat and water resistance than the more exposed AirPods.
The secure fit also helps deliver better sound than the AirPods. With multiple ear tip sizes and the hooks' stability, it should be easy to find a fit that creates a tighter seal to improve the audio further. Once you do, you'll find these have a nice sound signature with richer and cleaner output. There's bass if you're looking for that, which is even better when you find the proper seal.
If you carry a Lightning charging cable around for your iPhone, you can use the same one to charge up the case for these earbuds. It's not a small case, making it less portable than others, but at least there's a sizeable battery inside. You can expect up to nine hours per charge, with 24 hours coming from the case. So with a quick five-minute charge, you can squeeze out about 90 minutes of playback.
And since these are Apple-made, you get the H1 chip inside for super-fast pairing, plus always-on Siri for hands-free access. Of course, Android users can still use the onboard playback and volume buttons to control those things with relative ease.
Best on a budget
7. Back Bay Audio Tempo 30
Our expert review:
Reasons to buy
Reasons to avoid
For the price, it's hard not to like what the Back Bay Audio Tempo 30 can do for you, especially when they come in so many colors. Toggle on the Bass Mode for an extra thump while going hard during a run or workout. After you're done, give the Game Mode a shot, keeping things in sync whenever you're down to play games or watch shows and movies on your phone or tablet.
With six different ear tips in the box, odds are good you will find a pair that fit your ears. Unfortunately, you won't be able to block out background noise with the help of some ANC, or even talk to someone using the ambient mode, but the right fit should at least get you good passive noise isolation.
The Tempo 30 have IPX7 water resistance, making them more than good enough for rigorous workouts and sweaty runs. Don't swim with them, but feel free to wear them if you're lounging in a bath or tub afterward.
Expect up to eight hours per charge, assuming you're not blasting the volume, which will definitely drop that number. The case gives you another three charges, and your only option to charge them is via USB-C.
Best open-ear
Reasons to buy
Reasons to avoid
Shokz made the OpenRun Pro 2 for an active crowd, and these are among the best you can wrap around your ears to free them entirely.
Bone conduction headphones work by vibrations through your jaw and cheekbones to capture audio so that you can hear it that way, only without anything coming into contact with your ear canal. Shokz continues to be a significant player in this particular category, and these are among the best you'll find.
It made these with decent IP55 water and dust resistance to fulfill the need to stay active, whether running, cycling, or anything else you want to do. The open design means you will hear your surroundings, so for runners who want to know their environment, it's hard not to wear these headphones.
They spread out across the entire pad to help the skull absorb some of the audio output, and Shokz overhauled some of the audio playback for a richer and punchier sound. You can also download the Shokz app to utilize the onboard EQ. Bass is often the toughest part of the audio spectrum to reproduce with bone conduction headphones, so be mindful that you're not going to match what in-ear and over-ear headphones can do.
Battery life is good at up to 12 hours per charge. Shokz retains the same button layout that worked so well in the previous model, making it easy to play/pause or control volume during playback or phone calls.
How to choose
Time to put the work in
There are plenty of headphones or earbuds to choose from if you're only thinking about leisure, but rugged and durable ones are less obvious. The best headphones or best wireless earbuds don't always fit that bill because the focus is usually on function and fashion.
Good workout cans or buds need to be comfortable and stable, not to mention repelling as much sweat or water as they can. This list has something for every need and every budget.
The Jabra Elite 8 Active Gen 2 earbuds stand out as the best combination of durability and performance. They'll fit comfortably and offer excellent sound quality you can tailor however you like through the Sound+ app.
Do you need noise cancelation?
Many of these earbuds are equipped with ANC (active noise cancelation) which can eliminate background noise to help you focus more on your workout and less on the truck backing up outside the gym. Active noise canceling uses microphones on the earbuds themselves to detect and drown out noises coming from outside your headphones.
If you're riding your bike on an active road, however, ANC on your headphones can block out sounds that could warn you of a problem, such as a car weaving into the bike lane. Luckily ANC can be easily toggled on or off on headphones that support it, so you don't even need to take your headphones out of your ears if you change workouts.
Some headphones also support a passthrough mode to help you clearly hear what's happening around you. This can be helpful if you're trying to talk to someone, or simply want to hear the sounds of the world around you.
How we test
Testing headphones and wireless earbuds requires gauging how viable they can be in active scenarios. Some manufacturers try to address that by making their headphones or earbuds more durable to begin with. We look out for that at Android Central, and it's those models that get more scrutiny to make the cut for a list like this.
Simply being rugged isn't enough, though. We look for the best outcomes in how good they sound, how effective noise cancelation and transparency modes are, and whether battery life holds up to their claims. There are plenty of other factors and considerations that go into testing headphones and earbuds, but being able to withstand some punishment is sometimes a challenge.
We can't be certain how durable headphones or earbuds might be in the long run. Water and sweat resistance ratings give us an indication but some stewardship is necessary to extend their life if you routinely work out wearing them. We do our best to test for that, always noting whether or not red flags come up along the way.
Ted Kritsonis loves taking photos when the opportunity arises, be it on a camera or smartphone. Beyond sports and world history, you can find him tinkering with gadgets or enjoying a cigar. Often times, that will be with a pair of headphones or earbuds playing tunes. When he's not testing something, he's working on the next episode of his podcast, Tednologic.
- Jerry HildenbrandSenior Editor — Google Ecosystem
- Roydon CerejoContributor
