Best USB-C headphone adapters 2024
Keep your wired earbuds as a spare with these USB-C headphone adapters.
If you want to use your wired headphones with your smartphone or tablet, you might need a USB Type-C adapter to do so. Most of the latest phones, like the Samsung Galaxy S24 series, don't have headphone jacks anymore. But you can use an adapter in the USB-C port to use wired headphones in a pinch as a back-up, or simply if you prefer them.
The best USB-C headphone adapter on our extensively researched list goes to the JSAUX USB-C headphone charger, which allows for fast charging while you're listening to your favorite tunes. We've also included a multitude of picks that fit not only a variety of specific tech needs, but also varying styles and budgets. So let's get started!
Adapt and overcome with these USB-C headphone adapters
Staff pick
Best overall
The JSAUX USB-C audio adapter is our best overall pick thanks to its sleek design, and support for 60W PD fast charging. The aluminum housing and braided cable makes it durable, and the audio jack supports mic and in-line controls for your heaphones. It's compatible with a wide range of devices, and is priced well.
Most stylish adapter
This sleek-looking adapter allows you to listen to music and rapidly charge your device thanks to 60W PD charging. It works with several Type-C devices, including Google, Samsung, Motorola, Xiaomi, OnePlus, and other smartphones that lack a 3.5mm headphone jack.
Most compact adapter
If you want a more compact way to charge your phone and listen to your music, this is the best option for you. Simply plug it into the bottom of your phone, and then you can use the included headphone jack as well as the USB-C port as you see fit.
Best angled adapter
This tiny adapter lets you plug in your wired headphones, without getting in the way of your hands. The right-angled design sits flush against your phone, which is useful if you're holding it horizontally for watching movies or gaming. It also supports high bitrate audio output of 24-bit/ 96kHz.
Best adapter for old Lightning headphones
If you're looking for a way to use your Lightning headphones and accessories with USB-C devices, this is the adapter you'll need. There is no software installation required. Simply plug the USB-C into your phone or computer and then plug your lightning cable into the other end. Everything will automatically be good to go.
Best adapter for Samsung Galaxy phones
Samsung phone owners should get this headphone adapter to connect their wired audio devices, as it's guaranteed work on any device made by the company. As a bonus, it comes with a six-month warranty, and it supports 24-bit/ 192kHz High-Res audio playback.
Best two-pack adapters
Bojuren's USB Type-C to 3.5mm audio jack is an excellent value buy. You get two for the price of one, so you'll always have a backup pair. Keep one at home and one at the office, or one where you work and the other in your travel bag to enjoy high-quality music on the go.
Best adapter for tablets
If your tablet is missing a headphone jack, here's something to bring it back. The Anker 541 USB-C hub not only gives you a headphone jack, but several other expansion ports such as HDMI, USB-C, USB-A, and a microSD card reader. It's designed to fit snugly with an iPad, but it should work just as well with any USB-C tablet.
Best adapter for audiophiles
If you want to drive high-impedance headphones with your phone, you'll need a good DAC. The FiiO KA2 can easily power high-end headphones as it's able to output up to 32-bit/ 384kHz PCM audio. It's small, lightweight, and sturdy. Now, enjoy all your lossless music the way it was meant to be heard.
The best USB-C headphone adapters for wired simplicity
Many of the best Android phones are doing away with the headphone jack, like the OnePlus 12 for instance. Even Android tablets like the Samsung Galaxy Tab S9 Ultra have ditched the port. However, you can use an adapter with the USB-C port if you still want to use wired headphones. Fortunately, there are several different USB-C headphone adapters on the market from which to choose. Consider if you want the adapter to have any other functions beyond providing just a headphone jack. If you decide you want one that features a charging port, for example, you'll need to decide if you only want to support standard charging or PD fast charging.
We highly recommend the JSAUX USB-C Headphone Adapter since it provides a 3.5mm headphone jack and a charging port supporting PD fast charging. However, if you'd rather have something a bit simpler, you'll be interested in a Samsung USB-C to 3.5mm Headphone Jack Adapter, which only features a headphone jack. Both options are super compact and won't take up a lot of space in your pocket, purse, or bag. Last, if you're looking for an adapter that supports Lightning cables that come with wired headphones for older iPhone devices (the latest iPhones and iPads come with USB-C), you'll want to get the Anker USB-C adapter.
Get the top Black Friday deals right in your inbox: Sign up now!
Receive the hottest deals and product recommendations alongside the biggest tech news from the Android Central team straight to your inbox!
Rebecca Spear is a staff writer for Android Central who loves following the latest tech, drawing with her Wacom, and playing video games. You can find her posting about her pets, art, and video game preferences on Twitter @rrspear.
- Matt ShoreFreelance Writer
