Best USB-C headphone adapters 2025
While it's hard to beat the convenience of wireless earphones, there's nothing like the simplicity of using wired earphones. There's no charging hassle, and they always work as you'd expect. Most modern phones don't have a 3.5mm headphone jack anymore, but that's where the best USB-C to headphone adapters come in. This little cable converts your USB port into a headphone socket, making it easy to plug in any 3.5mm headphone or earphone.
The best USB-C headphone adapter on our extensively researched list goes to the JSAUX USB-C to 3.5mm Headphone and Charger Adapter, which allows for pass-through 60W fast charging while you're listening to your favorite tunes.
Adapt and overcome with these USB-C headphone adapters
The best USB-C headphone adapters for wired simplicity
Many of the best Android phones are doing away with the headphone jack, like the OnePlus 13 and Pixel 10, for instance. Even Android tablets have ditched the port. However, you can use an adapter with the USB-C port if you still want to use wired headphones. Fortunately, there are several different USB-C headphone adapters on the market from which to choose.
Consider if you want the adapter to have any other functions beyond providing just a headphone jack. If you decide you want one that features a charging port, for example, you'll need to consider whether support for standard charging is fine or you'd rather pay a bit extra for fast charging.
BENFEI USB-C to Audio Jack Adapter with DAC chipset
(Image credit: Namerah Saud Fatmi / Android Central)
We highly recommend the JSAUX USB-C Headphone Adapter since it provides a 3.5mm headphone jack and a pass-through charging port supporting 60W PD fast charging. However, if you'd rather have something simpler, you'll be happy with the cheap and cheerful BENFEI USB-C to Audio Jack Adapter with DAC chipset, which only features a headphone jack and comes with a built-in DAC. Both options are super compact and won't take up a lot of space in your pocket, purse, or bag.
Last, if you're looking for an adapter that supports Lightning cables that come with wired headphones for older iPhone devices (the latest iPhones and iPads come with USB-C), you'll want to get the Anker USB-C adapter.
Namerah Saud Fatmi
Senior Editor — Accessories
Namerah enjoys geeking out over accessories, gadgets, and all sorts of smart tech. She spends her time guzzling coffee, writing, casual gaming, and cuddling with her furry best friends. Find her on Twitter @NamerahS.
