Best GaN chargers 2026
Compact and portable chargers with plenty of power for fast charging.
The best chargers to buy today for laptops, Android phones, and everything in between these days are GaN chargers, short for Gallium nitride. Semiconductors made with Gallium nitride, like the Anker 313 Ace, can be smaller than traditional silicon chips, and smaller chips make smaller, lighter, and ultimately better chargers. The tech has been around for a couple of years now, but this is still a relatively small field. These are the best GaN chargers with Power Delivery charging you can buy today.
More power for your devices with compact chargers
Super Fast Charge 2.0 support
If you've got a new Samsung phone with 45W charging, you'll need a charger that supports the right PPS mode for Super Fast Charge 2.0. The Anker 313 Ace charge supports this power mode, as well as 45W with PD, so you can get fast charging speeds on just about any USB-C device.
The only charger you need
This UGREEN Nexode charger can deliver 100W of power over USB-C using a single port or up to 65W when charging two or three devices. Even with four devices at once, the top port gets 45W which is enough to keep many laptops, like Chromebooks, running while you charge up the rest of your devices.
Dual-port power
The Spigen ArcStation Pro is a larger GaN charger designed to provide stable power and stay cool. You can charge up to 100W on a single USB-C port or 45W each when using two. This is enough power to keep many laptops humming along while charging a phone or tablet as well.
A cuter charger
Who said chargers need boring utilitarian designs? This robot-themed charger from UGREEN can deliver up to 65W and has two USB-C ports and a USB-A port on the top for three-port simultaneous charging with up to 45W on the top port. When not in use, put the robot's magnetic feet back on for easy storage.
Monitor your charging speed
While the Sharge (formerly Shargeek) Retro 67 looks like little more than a novelty, this 67W three-port USB-C charger packs a real punch with full 67W output from any port. The display on the front is also functional showing your current charging speed, which is fairly rare with wall chargers.
Four ports where you need them
The Spigen ArcDock 65W 4-port charger doesn't need to plug directly into the wall with an AC power cable, allowing you to put this charger right where you need it. It can provide 65W to a single USB-C port and can split the power up in multiple ways to charge all of your devices at once.
Charge it all at once
This desktop charging station is compact and actually kind of handsome with that texture across the top. You can charge a laptop plus three peripherals at once, like a phone, smartwatch, and headphones.
Power for two 60W devices at once
The 120W ArcDock from Spigen increases the available power to 100W with a single USB-C charger and can deliver up to 60W to each USB-C port when charging two. Have a wireless charger for you desk? Get 18W of power on a USB-A port for it without giving up a single watt on the primary USB-C port for your laptop.
Sleek and stylish
Like the 65W four-port model, this is another nice-looking GaN charger that can charge either a phone, tablet, or laptop. It can also hide in a deck of playing cards if your coworkers tend to "borrow" yours.
A complete desktop power solution
The PowerCombo 65W Charging Station from Baseus can handle most or all of the power needs of a modern work-from-home desktop. Available in black or white for a better match, this charging station has up to 65W power delivery on one USB-C port and comes with two outlets for other devices like a monitor or standalone battery charger.
Portable power station
Mophie from Zagg has been powering our phones for years, but its Speedport 120W charger can top up every device in your backpack from a single plug. It has 120W of total output with three USB-C ports and a USB-A port. The top two USB-C ports can handle a full 100W of power, with the lower USB-C delivering 20W and the USB-A ports offering up to 12W.
Fast USB-A charging
This 100W Nexode Desktop charger can deliver up to 23.5W from the USB-A ports which is around double that of most other multi-port chargers. This can be nice for older tech using micro-USB that support fast charging. Besides that, you get three other USB-C ports with up to 100W of power delivering in single-port mode and 65W in two and three-port modes.
What GaN actually is and what it does in your charger
GaN stands for Gallium Nitride, an alternative to the traditional silicon that has dominated electronics for the last few decades. Gallium nitride has some advantages — a wider band gap means it's easier for energy to pass through it, and it has higher limits for the temperatures and power levels it can handle — that makes it almost tailor-made for higher-capacity tech like Power Delivery chargers for today's best Android phones.
In short, semiconductors and chargers made with gallium nitride are smaller and more efficient, which in turn can help them avoid heating up as much as traditional silicon-based chargers.
However, since the goal of most gallium nitride chargers is to be as small as possible, some GaN chargers still get uncomfortably warm when used for long periods of time because they don't have as much room for heat dissipation. You're not going to be able to bake a cookie on a GaN charger the way you can on a MacBook brick during an all-night editing session, but they'll still get a little warm depending on how hard you work them.
What makes the Anker 313 Ace the best GaN charger on the market
In an age where you can charge quite literally all of your tech via one protocol — from your laptop to your phone to all the power banks and headphones in between — one good Power Delivery charger with PPS can replace a dozen chargers. So if you can get away with a single-port charger — or you need a charger for your purse or backpack — the Anker 313 Ace is the perfect choice.
45W is the top speed for charging the best Chromebooks and many USB-C laptops, and it will charge almost all tablets at top speed, too! It can even deliver 45W charging on phones like the Galaxy S23 Ultra thanks to its support for Super Fast Charge 2.0. Just make sure you also grab one of the best USB-C cables with 5A support to use with it.
If you need to charge two devices at once — think of two students with Chromebooks for homework — the Spigen 120W ArcDock is a great pick. Not only does it have enough power for two power-efficient laptops at once, but it also has the ports to top up all of your essential devices once homework is done.
When Samuel is not writing about networking or 5G at Android Central, he spends most of his time researching computer components and obsessing over what CPU goes into the ultimate Windows 98 computer. It's the Pentium 3.
