Best smart locks 2025
Keep your home safe and sound with the best smart locks.
At a glance
1. Best overall
2. Best design
3. Best on a budget
4. Best premium pick
5. Best value
6. Best for Nest users
How to choose
Whether you're tired of losing your keys, you're already in the process of automating your home, or you're setting up a bed-and-breakfast, a vital part of the process is choosing the best smart locks that fit your needs. There are plenty of different smart locks to choose from, each with its own unique abilities. Some have easy installation, some work with virtual assistants like Alexa, while others are loaded with tech like built-in cameras to give added flexibility.
Though there are some great picks out there for securing your home, the best smart lock is one of the highest-ranked August Wi-Fi Smart Locks (4th Gen). The built-in Wi-Fi means it can connect directly to your home Wi-Fi without the need of a bridge. Others like the ones from Schlage can be quite expensive, but there's always a great deal to find if you know where to look.
If you're looking for something more specific, our best smart locks list has something in it for everyone.
At a glance
Best overall
If you want to keep things discreet, you can't do much better than the August Wi-Fi smart lock. It's only visible from the inside of your home, plus built-in Wi-Fi means you can access it anywhere from the August app.
Best design
Available in two color options, the Schlage Encode Plus connects to Wi-Fi directly, and works well with an Apple Watch for a keyless entry. It also pairs with all the major virtual assistants for easy voice commands.
Best premium pick
This pricey smart lock makes up for some of that cost by doubling as a video doorbell to go along with the excellent digital keypad, fingerprint scanner, and key slot covered by a solar panel to keep the batteries charged.
Best on a budget
The SwitchBot Wi-Fi Smart Lock is easy to install, comes with a keypad, has up to seven ways to unlock it, and two color options to match the look of your door.
Best value
The Lockly Flex Touch has a responsive biometric fingerprint scanner with the ability to save up to 99 fingerprints, plus a customizable auto-locking feature.
Best for Nest users
If you're already integrated into the Google Nest ecosystem, the Nest x Yale lock is an easy way to secure your smart home with intelligent smartphone controls and tamper alerts.
Best overall
Specifications
Reasons to buy
Reasons to avoid
Unlike many of the other smart locks that you'll find on the market, it isn't immediately apparent when you have the August Wi-Fi Smart Lock installed on your front door. That's because the device is installed inside your home, so there's no indication of the smart lock from your front porch. The latest model is still a little bulky but is much smaller than previous generations.
In our review of this August Wi-Fi lock, we loved that it was so simple to install with existing hardware while including so many advanced features. One of the things that makes this particular lock so great is that buyers don't need any additional bridges when using this device since it has its own built-in Wi-Fi. That means that buyers can lock and unlock the door anywhere as long as they have access to the August app and a good internet connection.
You can also view the activity of any entry where this smart lock is installed by checking the app. If you want, the app allows you to change the settings to automatically lock when you leave home or unlock when you approach. Plus, it works beautifully with Google Assistant, Amazon Alexa, and other smart home assistants.
Best design
2. Schlage Encode Plus
Our expert review:
Specifications
Reasons to buy
Reasons to avoid
If you're looking for a smart lock that offers a sleeker design, you'll be interested in this lock from Schlage. It looks beautiful, and there are a couple of colors and styles to match the look of your front door. The Encode Plus features a built-in alarm, and you can cycle through three different alert modes to let you know if there is any activity going on at your door. It also has built-in Wi-Fi, so setup with your home network is dead simple.
Open your door using a key or give out up to 100 access codes to your kids or guests so they can get in the house without a key. You'll even be able to monitor who comes in and out of your home using the activity log. You can customize the notifications to your liking, and even control it via assitants from Google, Amazon, and Apple. The only thing stopping many from grabbing this great smart lock, is the price. At around $300, it's quite expensive.
Best premium pick
3. Lockly Vision Elite
Our expert review:
Specifications
Reasons to buy
Reasons to avoid
Getting the negative part of this lock out of the way — it's expensive with a full price of $500. But, if you consider this a smart lock and video doorbell in one, then it isn't too bad. The lock comes with a fingerprint reader that can store and remember up to 99 prints in addition to the digital keypad that scrambles the order of the numbers each time you press one. While it may take a few more seconds to enter your PIN, it means that it will be more difficult for potential evildoers to guess it.
The Lockly Vision Elite is packed with lots of features, like a door sensor that'll notify you when your door isn't closed, and a very long battery life that potentially could last forever thanks to the solar panel built into the keyhole cover. The vision part Lockly Vision Elite's name is thanks to the video doorbell functionality included in this device. This lock is an all-in-one solution for securing your door.
With all of these features, you can reassured your home stays secure. You'll even get a notification if the lock thinks someone is tampering with it.
Best on a budget
4. SwitchBot Wi-Fi Smart Lock
Our expert review:
Specifications
Reasons to buy
Reasons to avoid
If you're looking for something that securely bolts your door shut without costing too much, then this is the smart lock to get. It features a wireless keypad with an optional fingerprint model available, and because it uses your existing lock, you won't have to get new keys. Aside from the keypad and physical key, you can also unlock it with your phone, an NFC card, voice via your favorite smart assistant, and more. However, to unlock it from your phone when you aren't home or with voice assistants like Alexa, you'll need the SwitchBot Hub 2 or the Hub Mini. The Hub 2 is Matter-ready, so I recommend that.
It comes in two colors to match your door: black or silver. The installation process isn't necessarily difficult, but getting the parts to line up properly can be a bit cumbersome. You won't need to remove your old lock, as this model uses a motor to turn the knob of your existing lock. Keep in mind that if your lock is a bit tough to turn, the SwitchBot Wi-Fi Smart Lock motor may struggle to turn it. Oh, and that interior part you installed is a bit clunky-looking.
Battery life for this lock is pretty good, rated at six months via the two CR123A batteries. Being able to have multiple ways to control the lock with or without the hub is great. Adding in the fact that you won't need to remove your old lock to install this one is great, though.
Best value
5. Lockly Flex Touch
Our expert review:
Specifications
Reasons to buy
Reasons to avoid
Keys are a thing of the past. Instead, biometric options, like your fingerprint, make opening your door faster and more secure. The Flex Touch employs a 3D fingerprint sensor, ensuring the lock doesn't respond to lifted prints. During my review of this lock with my family, I found that the fingerprint scanner was fast and secure. But should you need it, you can always fall back on the included keys.
Owners can also add up to 99 fingerprints and control the lock remotely with their phones. However, to use this feature, you'll have to purchase the Lockly Secure Link Wi-Fi Smart Hub selling for about $80 on Amazon. With the hub, you can also monitor the unlock history to see if something strange has been going on with your door.
If you're the kind of person who prefers to keep your front door locked at all times, then you'll appreciate the auto-locking feature. Set it to lock anywhere between five seconds and five minutes after opening the door. Just be aware that the deadbolt will lock regardless of whether or not the door is open.
Best for Nest users
Specifications
Reasons to buy
Reasons to avoid
The Nest x Yale Lock is a pricey option, but it has many useful features that make it a great purchase. Anyone whose home is decked out with Google smart devices will be able to lock, unlock, and check the status of this Yale lock simply by talking to Google Assistant. Remember that since this is a Nest device, it doesn't work with Amazon Alexa. You can also use the Nest app to control the deadbolt from just about anywhere or come up with temporary access codes to give to family or friends. As we saw in our review of the Next x Yale, this is an excellent lock for those already in the Google ecosystem.
Are you worried about security? If someone starts messing with your lock, you'll get a notification on your phone letting you know that something is going on. On top of that, if you have the Nest Secure alarm system, you can connect it to this lock, making it so that it disarms the alarm whenever you unlock the lock. This keeps your home secure without making it inconvenient for you. You'll find that this lock comes in three different colors, so you can find a look that fits your door: Oil-Rubbed Bronze, Satin Nickel, and Polished Brass.
How to choose
Which smart lock is best?
When looking for a smart lock, you want something that provides plenty of security features and added convenience for a reasonable price. Next, you'll have to determine if being able to lock via the app or voice assistant is enough or if you'd like the ability to key in codes, use a physical key slot, or even open the door via fingerprint scans.
There are a lot of great smart locks from August with a variety of features and formats to fit your needs. One of the best options out there is the August Smart Lock. It makes the front of your door look like any other lock, but you'll be able to monitor lock activity to know who is going or coming from the included August app. It's cheaper than several others because it uses Bluetooth rather than a Wi-Fi connection. Many of the smart locks on this list are also the best smart locks for Google Home, if you're already in Google's ecosystem.
Be an expert in 5 minutes
- Roydon CerejoContributor
