Best smart LED light bulbs that work with Google Home 2025
To experience all that smart LED lights can offer, you'll want to start with ones that are entirely customizable, offering the full spectrum of available colors. These bulbs are way more expensive than any light bulb you've probably bought in your life. So, you're going to want to choose a brand that can satisfy all your smart lighting needs. You might also prefer ones that can work all around the house without the need for a separate hub.
Not only are the best smart light bulbs more energy-efficient than traditional incandescent bulbs and even compact fluorescent bulbs, but you'll feel like Tony Stark walking through your home, controlling the lighting with just your voice.
Google Home is one of the tentpole home assistant platforms, and all of the bulbs listed here pair perfectly with the best Google Home compatible devices available. All you need to ask yourself as a shopper is how many bulbs you need for your home and how much are you willing to spend?
Full-feature smart lights with Google
Dimmable white smart bulbs with Google
Let's be real. Not every smart bulb in your home needs to cycle through 16 million different colors. And they can still be fully dimmable and react to your voice commands.
You can save some money buying white LED smart bulbs for the more mundane areas of your house, like hallways and bathrooms and save the fancier color bulbs for the areas where you entertain your guests. There are dimmable white smart bulbs available for each smart hub ecosystem and many options that only require a Wi-Fi connection.
Don't be afraid to mix and match
The best part about having so many smart light bulbs available that all work with Google Assistant is that you can have a hub set up and some individual Wi-Fi bulbs all running on your home network and still control everything using just your voice. Google has done a great job at making the process of adding smart lights to Google Home a relatively straightforward one.
Our top recommendation is the Philips Hue Starter kit, which includes everything you'll need to build your dream smart home. Hue certainly costs more than other brands, but the Philips Hue app and all its integrations make it simply smarter than other options.
These bulbs tie in perfectly with Google Home, and you can use Google Assistant to control every aspect of your lights, including powerful zone controls. The Philips Hue hub uses an ultra-reliable Zigbee wireless connection, which is independent of Bluetooth or Wi-Fi. That means your bulbs will work properly even if your home Internet connection is out or your phone doesn't have a perfect signal.
Matter support has also made its way to a few models, which makes setup and control even easier. If you have a Mattter-compatible hub like a Google Home, Google Home Mini, Nest Hub, or Nest WiFi Pro, you already have what you need.
But just because you have some Hue bulbs doesn't mean you can't mix and match brands to your heart's content. Google Assistant works with every brand on here, including the ability to change colors, dim the bulbs, and add them to routines. Bulbs like WiZ Connected are way cheaper than Hue without sacrificing much in the way of features, while accent pieces like the Nanoleaf Rhythm Smarter Kit add an extra flair to your home that simply can't be achieved by any normal-style lightbulb.
Samuel Contreras
When Samuel is not writing about networking or 5G at Android Central, he spends most of his time researching computer components and obsessing over what CPU goes into the ultimate Windows 98 computer. It's the Pentium 3.
With contributions from
